975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 02:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Potts bolt issue?
Author Topic: Potts bolt issue?  (Read 1545 times)
Offline SAFRANEV6RXE
Potts bolt issue?
« on: December 25, 2015, 09:30 AM »
I,ve just tried to fit a potts bolt to my NOS  S/R handlebar stem but it won,t fit,its to wide?is there another slimer version onf the bolts or do i have to change the stem?
Offline workshyfop
Re: Potts bolt issue?
« Reply #1 on: December 25, 2015, 10:00 AM »
potts bolt needs to be wider than a standard bolt to allow the cable to fit though it. you will need to drill out the stem hole to a suitable size.
Offline gary4130
« Reply #2 on: December 25, 2015, 10:03 AM »
i've always had to drill the top of the stem wider to get the bolt to fit -done this on sr stems since the '80s-dont know if you'll want to do this with a nos stem though
« Reply #3 on: December 25, 2015, 10:07 AM »
I can take the stem to a machiners after the hols and get it drilled,but i may look for an upgrade,i like the GT mallet type like this.
http://www.ebay.co.uk/itm/OLD-SCHOOL-BMX-GT-MALLET-STEM-SR-MADE-MID-1980s-/181970544502?hash=item2a5e4a2776:g:qsoAAOSwf-VWbUhZ
But i don,t like the price much!
Is it the full inner length that needs drilling or just the start?
« Reply #5 on: December 25, 2015, 10:24 AM »
Thanks chaps,just looking at it theres a sleeve at the top about 5mm can that be drafted out from the inside or is it a drill job only?
« Reply #6 on: December 25, 2015, 01:21 PM »
Some stems only need 1-2mm drilled out to fit the potts mod bolt.  :)
rodriguez
« Reply #7 on: December 25, 2015, 01:29 PM »
Fire a pic or two up before you do anything   :daumenhoch:
« Reply #8 on: December 25, 2015, 08:13 PM »
All done took my time and now the potts bolt is fitted..
Had a NOS ACS gyro given to me today aswell but not sure if it will fit my Burner?,looks great but not sure if its going to fit?
I was going to go down the route of longer cables and the potts bolt setup,a pic of the exact way the cable should be routed and fixed to the front caliper would be handy.
Offline bobbbbsy
« Reply #9 on: December 25, 2015, 08:38 PM »
 ^"^ burnerlove
Offline deeman
« Reply #10 on: December 26, 2015, 02:16 AM »
You need to route it down the inside or outside of the fork and loop it up to reach your caliper. You will probably need to hold it in place with a tie or two or Velcro straps. I will get a pic of mine tomorrow for you if you are still stuck. What caliper do you have? Has it been modded to accept the cable upside down?  The ACS Rotor will fit no problem, you just need to run the stem a bit higher to allow for the travel of the rotor. There should be plenty of images on the net of rotors set up. They are not brilliant and can be a pain to set up but you should be able to achieve decent stopping power with a bit of fiddling  :daumenhoch:
« Reply #11 on: December 26, 2015, 09:45 AM »
Thanks for the advise look foward to a pic to help.
I messed about with the adjusters yesterday and everything seemed to fit fine.
