976120 Posts in 138973 Topics by 6407 Members - Latest Member: Aristomenis 1974 December 14, 2025, 07:00 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Re-chrome costs and where to go
Author Topic: Re-chrome costs and where to go  (Read 6675 times)
Offline Noste500
« on: October 13, 2015, 10:22 PM »
Bear with me I'm learning ;-)
Bought a mongoose Cali 84 f&f for a build ..and the chrome isn't the best in places .
How much roughly to do f&f ( although my forks arn't as bad as the frame )
Also anywhere in the northwest recommended ?
I suppose other option is powder coat , but not sure I want it without chrome ..;-)
Would I have to have the chrome stripped before powder coating if I went that route ?
And rough cost on this route ??
Thanks in advance .
Offline oldscool
Re: Re-chrome costs and where to go
« Reply #1 on: October 14, 2015, 09:25 AM »
Im sure you can powder over chrome so you could go back and loads cheaper. Im sure somebody will be along soon with more words of wisdom. :daumenhoch:
If in doubt flat out.
Offline That Swan Guy
« Reply #2 on: October 14, 2015, 09:32 AM »
You can powder over chrome but if the chrome is bad the powder will show it and it can peel easily. It is cheap to get it stripped properly, not blasted, stripped. Go to the local chromers and they will reverse the process. It's fairly quick and will lend itself to a far better powder job. A full re-chrome frame and forks is anywhere from £250+ The more you pay the better the job.
Cheapest and best option is de-chrome & powder
If you chrome the frame you will need to do the forks as the chrome will be a different colour
Offline CustardLips
« Reply #3 on: October 14, 2015, 09:39 AM »
There's Leigh Metal Polishing in Swinton Mcr if you want it re-chroming and they can also de-chrome it if you go for powder.  :daumenhoch:
"WWG1WGA"
  • Andy
« Reply #4 on: October 14, 2015, 10:30 AM »
Leigh Metal Polishers have done LOADS for me, and are excellent. Speak to John on 0161 728 4325. Turnaround time is usually about 8-12 weeks - sometimes less for smaller items. The cost to strip, prep and re-chrome a frame is approximately £140-£300, depending on where you go and how much prep work is needed. Before you give your frame to anyone, make sure they know exactly what you want, and make sure they know not to polish out serial numbers/stamps etc. No need to hammer this home with John @ Leigh Metal Polishers, as they are spot on and do loads of classic bikes/car parts. Here's one they did for me earlier (as they say on Blue Peter). Absolutely flawless. Frame is now owned by another forum member Retrodan.
Offline oldscool
« Reply #5 on: October 14, 2015, 11:10 AM »
That chrome doesn`t look flawless to me, you can see a camera in it  :LolLolLolLol:
Offline Noste500
« Reply #6 on: October 14, 2015, 06:26 PM »
Thanks a bunch fellas ;-)
