975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 01:46 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Please help with Skyway Tuff II axle thread info!
Author Topic: Please help with Skyway Tuff II axle thread info!  (Read 2917 times)
Offline Old School
« on: October 08, 2015, 06:33 PM »
Hi again everyone!
Sorry to pester but I'm right at the end of my build and I have a couple of snags!
The first is being dealt with in another thread.
The second is fitting old school skinny trick pegs on my Skyway axles!
Here are photos so u know what the hell I'm talking about!!
Question A: the dropout on the freewheel side, in the 1st & 2nd photos, is bent in a bit now the nuts are tightened - should I be using more spacers between the freewheel and the dropout so that the dropout is straight?
Question B: the skinny pegs I've got don't screw all the way down to the outer drop out nut on both sides.
So presumably I'll need more spacers?
Question C: where do I get the spacers or what TPi nuts do I need?
Cheers guys :daumenhoch:
Offline monteryroom
Re: Please help with Skyway Tuff II axle thread info!
« Reply #1 on: October 11, 2015, 09:15 PM »
i would take some length off the axle. do it with the nut on so it retraces the thread on the way off.
we used to use the screw on pegs instead of axle nuts.  thread them all the way on, flush against the drop.
you could use chain tensioners under the pegs, too.
Offline monteryroom
« Reply #2 on: October 11, 2015, 09:20 PM »
http://bmxmuseum.com/forums/viewtopic.php?id=242071
^^some good info here^^ from the man himself, planet bmx: (colored tuffs store).
"95% of all Tuff Wheels out there,
 including all of my colored Tuff Wheels that I've had made since 2004 are a 26tpi / 24tpi combo.  The front is a 26tpi, and the rear is a 24tpi". .
Offline 58 delray
« Reply #3 on: October 12, 2015, 11:06 AM »
in answer to question "A" yes you should space the axle/wheel to the frame and not pinch the frame in  :daumenhoch:
