975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 08:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ACS Boa front flex
Author Topic: ACS Boa front flex  (Read 1451 times)
Offline EDBANGER
ACS Boa front flex
« on: September 21, 2015, 11:19 AM »
I've got a 6mm ACS caliper and it's got some flex in it when the brake is applied.  I thought the whole point of the Boa and it's sealed bearings was it got rid of the flex?  Can it be serviced to make it solid again or is it a case that the bearing seals are knackered?
Offline Gnarlyscoots
  • BANNED
Re: ACS Boa front flex
« Reply #1 on: September 21, 2015, 01:03 PM »
This works a treat  :daumenhoch:
BANNED
« Reply #2 on: September 22, 2015, 03:47 PM »
or cable ties  :)
Offline midschooljon
    • Make Your Bones
« Reply #3 on: September 22, 2015, 09:38 PM »
There shouldnt be flex in the Boa if it is servoced properly. The bearings are loose ball so the seals have no impact on the flex. Just make sure it is all tightened properly and running smooth. If it still flexes it will be in the actual 6mm bolt (which is why they all broke there.
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Offline chubby
  • Needs Pegs
« Reply #4 on: September 22, 2015, 09:56 PM »
You need to undo the round cover on the front to reveal the nut or flats on the spindle end. Then the round thing at the back of the brake arms has some little holes in, hold the front of the spindle with a spanner & find a suitable weapon to jam in the little holes in the round thing & tighten it up a bit..
Makes total sense to me , hope it does to you to  :LolLolLolLol:
