975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 07:32 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Any recommendations for reviving a plastic saddle?
Author Topic: Any recommendations for reviving a plastic saddle?  (Read 2820 times)
« on: July 20, 2015, 12:01 AM »
Can anyone recommend any products to help revive a saddle that's looking a bit tired? (Textured surface, fine scratches)
Re: Any recommendations for reviving a plastic saddle?
« Reply #1 on: July 20, 2015, 07:55 AM »
you been turning it upside down on the concrete again John??
« Reply #2 on: July 20, 2015, 09:49 AM »
« Reply #3 on: July 20, 2015, 11:18 PM »
 :tumbleweed:
« Reply #4 on: July 20, 2015, 11:24 PM »
Spose I'll have to chime in.... Pics please griffster  :)
« Reply #5 on: July 20, 2015, 11:49 PM »
Saddle's not in the house right now, will get some up tomorrow night (off to see SBD in the morning :) )
Seem to recall someone managing to freshen up a saddle with some of that stuff they use on car bumpers, or did I imagine it...?
« Reply #6 on: July 21, 2015, 02:15 PM »
Various ways to revive a saddle depending on the make, the colour and texture.  Deffo need pics.
« Reply #7 on: July 22, 2015, 02:19 AM »
Sorry, didn't get back till late - will get some pics up ASAP
« Reply #8 on: August 03, 2015, 09:37 PM »
Ok sorry for late follow up but had a few things going on
Gave the seat a bit of a clean up and took some shite iPhone pics, but here's a brief summary
Top of saddle is textured, but looks like it's been put on the ground at some point in its life
Sides are smooth and have the odd fine mark
Rails & guts need a clean up
Biggest issue though is on one of the 'loop' thingies at the back, when it arrived one of them was sticking out of the package & it looked like the postie had dragged it down a rough wall (Cnut) while I've been able to gently file off some of the worst snags it still looks a bit worn down :(
Just found out Mrs griff actually has some citric acid powder in stock (apparently it can be used for things other than restoring bike bits - imagine that?!) so will try the seat guts in that, any suggestions for something to help revive the plastic gratefully received x
« Reply #9 on: August 03, 2015, 09:39 PM »
Actually looking at those pics it doesn't look that bad, it's a bit worse in real life up close
« Reply #10 on: August 03, 2015, 10:13 PM »
Yep, junkies use it when they cook gear on a spoon, although mrs griff may well just clean things with it.
« Reply #11 on: August 03, 2015, 10:20 PM »
Great tip  :daumenhoch:
Apparently oven pride can also be used to clean ovens  :D
« Reply #12 on: August 03, 2015, 10:22 PM »
I would tickle up the smooth bits as best you can and leave it at that, the textured stuff is far too textured on those Brooks saddles to be sanding
« Reply #13 on: August 03, 2015, 10:30 PM »
What would you tickle them with?
« Reply #14 on: August 03, 2015, 10:33 PM »
Progressive grades of wet or dry followed by a polish. You can get plastic polishes but t cut or probably peek would work just as well on a black seat I imagine  :)
Offline chubby
  • Needs Pegs
« Reply #15 on: August 03, 2015, 10:34 PM »
Rail side down In the citric chum. Like Clint says I wouldn't go bononkers on it , you'll end up making it worse & might hurt your hand or something  :P
Offline chubby
  • Needs Pegs
« Reply #16 on: August 03, 2015, 10:36 PM »
That silvo worked well on them Perry seats, buff it off sharpish Griff or you'll be scrubbing it out of the nooks n crannies for ages
« Reply #17 on: August 03, 2015, 10:50 PM »
I was hoping you'd say Peek
Offline chubby
  • Needs Pegs
« Reply #18 on: August 03, 2015, 11:04 PM »
Well you can use it on the rails  :teef:
