What sizes are they in metric?If they are listed as 700c then dividing the 700 by 25.4 will give you them it in inches = 27.55
I can see what you mean. These days they don't stamp rims with those dimensions.If you measure an Araya 20x1.75, it's not 1.75"wide, it's the minimum Tyre width recommended for use. 2.125 is the minimum tyre width recommended for use with that rim (although you could use a 1.75 tyre on that rim, just like you can run a 1.75 tyre on a 1.5 rim.)
http://mombat.org/MOMBAT/BikeHistoryPages/Araya.htmlIt looks like they were all 32.2 wide, apart from the ones stamped 1.5 ( 7XN ) and obviously 1 3/8.
