975757
TattooedYorkie
September 27, 2024, 05:20 AM
Old School BMX 1980 - 1988
Vintage Profile cranks and numbers...
Topic: Vintage Profile cranks and numbers... (Read 2300 times)
SAND N DIRT
September 12, 2005, 08:07 AM »
In the very beginning of the history of Profile cranks, crankarms were numbered. Not by length, but just by number in order of fabrication. Now, I've found these cranks and they have a number engraved and was wondering what kind of different lengths the Profile cranks were made? For example, if I take a closer look at a vintage printad for these cranks, they say 170mm, 175mm, 177mm, 180mm, Special 165mm, 185mm, 190mm, 195mm (BMA Action June 1983). Now, as my cranks have number 182 and have measured them and they are 182mm from the center of the whole of the spindle to center of the pedalspindle. How do you explain this?? Does this mean that I have cranks of a different size OR do I need to measure differently OR is the serienumber similar to the length of the arms? PLEASE HELP!
Thanks a lot.
SND
ORB
Founding Fathers
My life is Radbmx
Posts: I am a geek!!
Re: Vintage Profile cranks and numbers...
September 12, 2005, 11:53 AM »
Spagetti
SAND N DIRT
September 12, 2005, 12:29 PM »
With tomatos??
What do you mean ORB?
SAND N DIRT
September 12, 2005, 03:23 PM »
...is my English really that bad?? !
diesel
Look Back
September 12, 2005, 03:39 PM »
Sander:
I will check this evening if I can remember.
I have second generation box cranks with the indent for the decal or are you only talking about the first generation box cranks?
SAND N DIRT
September 12, 2005, 04:06 PM »
2nd generation with that indentthingie.
SAND N DIRT
September 12, 2005, 04:07 PM »
...but how come that lenght of 182mm is not listed in the printad as mine are 182??? Perhaps I measure the arms wrong, could be...
diesel
Look Back
September 12, 2005, 04:11 PM »
Printad =?
Do you mean brochure (printed documents taht come with the item)
I will check mine I think they are 180mm and stamped 180
SAND N DIRT
September 12, 2005, 04:23 PM »
yes... printad... of Profile probably you are not aware of this or perhaps forgot.
But I shall try to find some time to scan it for you.
Is it rare a crankset of Profile in size 182mm?
pkradman
September 12, 2005, 10:10 PM »
i have some gen 1 profile cranx and the only numberd markings i can see just show this (128-176) any ideas what this means ..
SAND N DIRT
September 13, 2005, 09:56 AM »
Well that means you have #128 and #176 pkradman!
So therefore I was wondering, as my cranks have BOTH(!) number 182, they are number 182...
but isn't it pretty coinfidence that the lenght AND number are all the same, while Profile didn't sold 182mm cranks? Or they did???
SAND N DIRT
Reply #11 on:
September 19, 2005, 06:39 PM »
BMX ACTION OCTOBER 1984 P32
PROFILE ULTRA LITE MINI CRANKSET
"Now Profile has some trick three-piece aluminium cranks for 'lil dudes. Hot-diggety! These aerodynamically tapered aluminium honeys have a replaceable spider, precision sealed bottom bracket bearings, and are available for European, American, and Profile Magnatanium bottom brackets. Take your pick of an aluminum or titanium spindle. Crank lengths include 152mm, 160mm, 165mm, 170mm, and they'll even do CUSTOM ones for ya. PROFILE RACING."
So... that means that these cranks I have are CUSTOM made size 182mm!
Stu uk Liverpool
Reply #12 on:
September 19, 2005, 09:27 PM »
WEL RADMAN
YOU WOULD YOU POSING GET
STU
SAND N DIRT
Reply #13 on:
September 20, 2005, 11:21 AM »
Don't understand, what do you mean?
24Mhz_Cruiser
Reply #14 on:
September 20, 2005, 12:11 PM »
Profile UK have a technical support forum:
http://www.profileeurope.co.uk/Profile_BB.htm
Might be worth asking them to clarify things for you?
