975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 02:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  motomag/1pc crank/sprocket issue
Author Topic: motomag/1pc crank/sprocket issue  (Read 579 times)
Offline Philbert
« on: June 23, 2015, 08:34 AM »
Got a bit of an issue!
Has anyone had trouble putting a 44t sprocket on a motomag?
When building with one spacer behind the sprocket the teeth catch on the chain stay. If I use two spacers there isn't enough thread for the retainer washer on the locking side?
Its a mongoose pressed steel sprocket that was common on the motomag so the teeth are stepped in a bit
