975797
Bmxflex
November 16, 2024, 12:52 PM
BMX General
BMX Chat
Freecoaster adjustment
Topic: Freecoaster adjustment (Read 1087 times)
gary67
Rockwalk
June 08, 2015, 12:35 PM »
I have a freecoaster setup on my bike, the wheel is of a DK Opsis, anyone know what freecoaster they used and how to adjust them, as i feel there is too much slack in it, cheers
john4130
Look Back
Re: Freecoaster adjustment
June 08, 2015, 06:13 PM »
don't know what freecoaster it came with but it's most likely to be a standard set up. take off the drive side cone nut then unscrew the driver, the axle should slide out the opposite side. seperate the spring from the clutch and check if there's any washers inside the clutch, chances are there won't be any so you will need to add some, they will need to be able to fit inside the clutch, i added three to mine which gives very little slack, i also had to file them down a bit to fit inside.
you can see the washers i added in the pic inbetween the spring and clutch.
fugazi
Site Supporter
540 Air
June 08, 2015, 06:54 PM »
You probably have a Taska freecoaster like in the pic above, what john has said is all about you can do with those, when you've got it apart check the spring isn't knackered, that's usually what causes all the slack & non engaging.
gary67
Rockwalk
June 09, 2015, 02:09 PM »
Cheers peeps, will take it out and have a butchers at it
gary67
Rockwalk
August 04, 2015, 04:55 PM »
Taken the freecoaster apart,its a taska just the same as above,now it doesn't work, only in reverse? Pedal forwards..not engaging, pedal backwards it engages. Taken to bits now about 8 times no luck??
john4130
Look Back
August 04, 2015, 07:16 PM »
when putting it back together make sure the washers and the spring are inside the clutch, the bit attached to the small side of the spring will have a couple of flat edges, this part slides inside the cone on the left in this pic.
this is how it should look before inserting it back into the hub.
once it's slid into the hub, screw the driver back on and then the cone nut.
gary67
Rockwalk
August 08, 2015, 03:11 PM »
gary67
Rockwalk
August 21, 2015, 02:15 PM »
Cheers chaps,all sorted now
john4130
Look Back
August 21, 2015, 04:58 PM »
did you add some washers? if so, is the gap ok now.
Last Edit: August 21, 2015, 05:00 PM by john4130
BMX General
BMX Chat
