975755
TattooedYorkie
September 22, 2024, 12:33 AM
U Brake springs
Topic: U Brake springs (Read 741 times)
HUTCHMAN
540 Air
U Brake springs
May 23, 2015, 01:19 PM »
had a memory fade
... which side is the gold and the black spring for ?
TwoBobRob
Site Supporter
900 Air
Re: U Brake springs
May 23, 2015, 01:42 PM »
Depends on the brand but gold on the left more often than not.
The spring should coil in when in use and recoil outwards to release the arm.
HUTCHMAN
540 Air
Re: U Brake springs
May 23, 2015, 02:02 PM »
it's a hombre' rear brake .. cheers for you help
Gary72
Site Supporter
BMX Nerd
Re: U Brake springs
May 23, 2015, 07:37 PM »
https://www.danscomp.com/install/DiaTech_Hombre_Rear_U-Brake_Install.pdf
HUTCHMAN
540 Air
Re: U Brake springs
May 23, 2015, 09:14 PM »
thank you so much for that
U Brake springs
