975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 05:34 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chainring teeth numbers
Author Topic: Chainring teeth numbers  (Read 576 times)
Offline Rusty 73
« on: May 13, 2015, 10:20 PM »
Currently running a 44t, if I were to change to a 45 or 46 do l ave to change anything else like the chain. Sorry to ask, answer is probably obvious, but not sure    :uglystupid2:
The wife says most blokes buy a flash car or a fast motorbike when they turn 40 ...........
Offline Gnarlyscoots
  • BANNED
Re: Chainring teeth numbers
« Reply #1 on: May 13, 2015, 10:26 PM »
What are you running on the rear buddy?
What frame is it?
How much room do you have in the rear drops?
It should be just a case of adding 3 or four links to the chain. If your axle sits near the end of the drops, you may only need a couple if you have the room to slam it. You will need to ensure your calliper is suitable for that too, arm length wise.
« Last Edit: May 13, 2015, 10:28 PM by Gnarlyscoots™ »
BANNED
Offline snoopy72
« Reply #2 on: May 13, 2015, 10:35 PM »
All depends where your wheel is in the dropouts, normally get away with the same chain with 1 tooth larger providing the wheel is in the middle of the dropout
