975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 18, 2025, 02:58 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Re-sticking stickers
Author Topic: Re-sticking stickers  (Read 782 times)
Offline Gary72
« on: May 12, 2015, 08:45 PM »
Just taken a sticker off of a rim using lighter fluid, Nothing wrong with the sticker just going to bling up the rim.
Anyone know if there is a trusted method for re-sticking the sticker. Was thinking about spray mount but am worried that it might peel off after awhile or if it gets wet.
Wouldn't worry if it wasn't on a rim and spokes go through the decal.
Gary
Offline midschooljon
    • Make Your Bones
Re: Re-sticking stickers
« Reply #1 on: May 12, 2015, 09:03 PM »
The best way is with double sided tape. Not the fat foam stuff, the thin adhesive type. Make sure the old decal is completely clean (all old residue removed). Then take it and stick it onto the double sided tape. If the sticker is wider than the tape you may need to do a stripe or two extra. Trim around the decal before peeling the back ing off. Pull backing off and stick!  :daumenhoch:
A few things to keep in mind.
1) make sure you use the very thin stuff.
2) some tapes have a yellowish tint to the glue so this is best used on solid coloured decals.
3) if you are using clear backed decals you will need to experiment with tapes to ensure you find one with a clear adhesive.
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Offline Gary72
« Reply #2 on: May 12, 2015, 09:08 PM »
Thanks, It is a Primo Hula Hoop decal so is black with gold so not in the least bit see through.
Will have a raid of the kids craft box :daumenhoch:
« Reply #3 on: May 14, 2015, 10:21 AM »
Have you tried asking Primo if they have any spares you could have Gary?  ???
