975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 10:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bent seat post
Author Topic: Bent seat post  (Read 2427 times)
Offline CustardLips
Bent seat post
« on: April 11, 2015, 09:34 AM »
Got a slightly bent seat post and wondering if it can be straightened without fookin the chrome up ? It's not show chrome but tidy enough for my liking so don't wanna be fookin about stripping it and re-chroming it and all that carry on.  :-\
"WWG1WGA"
Offline Bigfrawg
Re: Bent seat post
« Reply #1 on: April 11, 2015, 01:43 PM »
Yes
Offline CustardLips
Re: Bent seat post
« Reply #2 on: April 12, 2015, 11:03 AM »
Yes
Thanks for your in depth reply Mike.  :LolLolLolLol:
How or who could do this for me... i guessing it's not just a case of whacking fook out of it with an hammer.   :-\
"WWG1WGA"
Offline insectbones
Re: Bent seat post
« Reply #3 on: April 13, 2015, 09:28 AM »
Sandbag and a big rubber mallet Nick, whack the fook out of it  :daumenhoch:
Offline CustardLips
Re: Bent seat post
« Reply #4 on: April 13, 2015, 03:11 PM »
Was expecting a more technical approach tbh Lee... but may be worth a try.  :daumenhoch:
"WWG1WGA"
Offline CustardLips
Re: Bent seat post
« Reply #5 on: April 13, 2015, 03:17 PM »
"WWG1WGA"
Offline Bigfrawg
Re: Bent seat post
« Reply #6 on: April 13, 2015, 04:58 PM »
Sorry mate got distracted , I got a piece of wood , drilled a hole same size as post and then clamped it in a vice and then protected post with a cloth and slid a larger diameter pipe over the top and carefully bent it back .
Offline CustardLips
Re: Bent seat post
« Reply #7 on: April 13, 2015, 07:06 PM »
Good idea for a straight seat post... think it may be a bit tricky with this one tho.  :-\
"WWG1WGA"
Re: Bent seat post
« Reply #8 on: April 13, 2015, 08:26 PM »
I did this below by machining a metal bar 0.5mm smaller than the internal diameter of the post and doming the end and driving it down inside, post weighed a touch more after! But it was steel ruler straight and was never going to bend again
Offline CustardLips
Re: Bent seat post
« Reply #9 on: April 14, 2015, 10:28 AM »
 :shocked: Fookin hell Jaymz that must of took some whacking.  ???
"WWG1WGA"
Offline Dannywhac
  • return of the whac
Re: Bent seat post
« Reply #10 on: April 14, 2015, 10:33 AM »
Could you not schlep one of them internal plumbers bending springs into it, and do the sandbag/rubber mallet jobby on it Nick?
Offline CustardLips
Re: Bent seat post
« Reply #11 on: April 14, 2015, 07:48 PM »
Don't think I'd get one in Dan... think the bends too close to the top. Might just fit it and see how it looks. If it's noticeable I'll probably go with the rubber mallet/sandbag approach.  :-\
"WWG1WGA"
Offline Bigfrawg
Re: Bent seat post
« Reply #12 on: April 15, 2015, 07:03 AM »
I would be surprised if you could get a plumbers spring up there , tried it with one of mine . Maybe try a sparks conduit spring or sand load it then give it the hammer treatment .
Failing that just buy a new one ya tight fooker  :D
Offline CustardLips
Re: Bent seat post
« Reply #13 on: April 15, 2015, 08:01 AM »
:LolLolLolLol: I've just bought this fookin one off the bay of pigs but no mention or pics of the bend.  >:(
"WWG1WGA"
