975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 10:54 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  S&M Fastpitch forks with lugs, cable routing issue
Author Topic: S&M Fastpitch forks with lugs, cable routing issue  (Read 2389 times)
Offline paulb113
« on: March 19, 2015, 08:41 PM »
I just bought a pair or S&M Fastpitch forks and the top cap isn't big enough to route a cable through so I asked the guy I got them off and got this reply
YEP I did run a front brake YA have to split the cable have top half with a ferrule going in to the top then turn YA bike upside down remove front wheel and run the bottom cable from underneath hope this helps or YA could simply and carefully drill the hole out but be very careful CUZ them top caps am £10 !! Not sure which other top caps fit ??
Anyone else run a front brake on a new school bike this way?
Offline fugazi
Re: S&M Fastpitch forks with lugs, cable routing issue
« Reply #1 on: March 19, 2015, 09:07 PM »
S&M do use a smaller compression bolt than most, I've got some pitchfork xlt's with 990 mounts & if you're careful you can drill through the top cap enough to run a cable through, the way the fella said will work as well but sometimes it doesn't feel as smooth.  Make sure you don't ruin the broached hex recess though!
Offline Gary72
« Reply #2 on: March 22, 2015, 10:07 PM »
If you get stuck, I've got some Oddy flat land forks. Pics here
http://www.radbmx.co.uk/forum/index.php/topic,181316.0.html
Offline paulb113
« Reply #3 on: March 23, 2015, 04:08 PM »
Got a bolt off an old Haro that fitted so it's all routed through and working,not best looking solution may try to drill the one that the forks came with
Offline Gary72
« Reply #4 on: March 28, 2015, 08:51 PM »
Get the drill out and if you do damage the allen key section follow Jim's advice
http://www.radbmx.co.uk/forum/index.php/topic,172329.msg1731557.html#msg1731557
Offline paulb113
« Reply #5 on: March 28, 2015, 09:48 PM »
Thanks Gary, Jim  :daumenhoch:
Offline paulb113
« Reply #6 on: March 28, 2015, 09:49 PM »
Offline paulb113
« Reply #7 on: March 31, 2015, 03:16 PM »
Drilled out and ready to fit,no damage to allen key head. Should look a lot neater
Offline paulb113
« Reply #8 on: March 31, 2015, 06:36 PM »
Offline paulb113
« Reply #9 on: April 15, 2015, 06:20 PM »
New brake blocks and front brake really sharp now :daumenhoch:
Offline fugazi
« Reply #10 on: April 17, 2015, 08:10 AM »
Told you going through the top cap works, looks real good! Great tailwhipping action going on there!  :daumenhoch:
