975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 08:11 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Any of you lads do media blasting?
Author Topic: Any of you lads do media blasting?  (Read 831 times)
« on: February 19, 2015, 08:25 PM »
Alreet lads :)
I've got an idea for some cranks and am looking to get them media blasted with baking soda, walnut shell or something similar to achieve a matt nice flat alloy look but without the overly granulated look of heavier media.
Tried wet or dry and fine wire wool but it's impossible to get a truely even matt look. Don't want to trust them to a company that don't appreciate the finesse needed so who can help me?
Offline sawzall
Re: Any of you lads do media blasting?
« Reply #1 on: February 19, 2015, 09:03 PM »
Try a red layered scotch bright wheel on a polishing
Mop clint,great for a satin finish
« Reply #2 on: February 19, 2015, 09:12 PM »
Cheers Phil will give it a whirl, hopefully it should just get in around the spider. Did think about a light etch with oven cleaner but the parts I have stripped in the past have never had a totally even finish :(
Offline Bfellows
« Reply #3 on: February 19, 2015, 09:15 PM »
You need to tumble them rather than blast for a nice matt even finish - have a mooch through the yellow pages for metal burnishers ;)
« Reply #4 on: February 19, 2015, 09:20 PM »
I've actually got a vibratory tumbler and was playing with it this evening but it's not really big enough for a crank arm. I know a company in Birmingham but I plan on leaving the face of the arm and the spider rim polished so would be easier to mask off for shot blasting.
will get a pic of thermal up in a min :)
Offline Bfellows
« Reply #5 on: February 19, 2015, 09:26 PM »
Awkward sod ;)
« Reply #6 on: February 19, 2015, 09:29 PM »
Here she is. Want it all matt grey with high polish on the Fuji logo surface
Offline Bfellows
« Reply #7 on: February 19, 2015, 09:37 PM »
Could you not tumble them then re polish the other bits......?
« Reply #8 on: February 19, 2015, 09:44 PM »
Probably but i hate polishing and the faces are only a wipe over with some peek away from being perfect  :-[
Offline dp and chopper dude
« Reply #9 on: February 19, 2015, 10:46 PM »
Could you attach a container big enough for the crank arms and the media to a sander (or other power tool) and vibrate it that way?
Or even make your own blaster like this one:
 I'm sure you'd be able to knock something up.
« Last Edit: February 19, 2015, 10:58 PM by dp and chopper dude »
« Reply #10 on: February 19, 2015, 11:05 PM »
I have already "upgraded" my tumbler with a few mods and it will now vibrate heavy cone shaped media but a bigger bowl would render it useless :(
might try and find a pal with a compressor and go the homebrew box of baking soda route
Offline Bfellows
« Reply #11 on: February 20, 2015, 09:12 AM »
Must be a decent soda blasters in your neck of the woods?  For the £5 it would cost on a dinner break special I'm sure they'd sort it for you?
« Reply #12 on: February 20, 2015, 10:06 AM »
That's something you don't hear every day  :teef:
« Reply #13 on: February 20, 2015, 10:40 AM »
 :LolLolLolLol: have to do it in the man shed, the missus finds the noise I make really annoying  ;)
Think you might be right Bert after a bit of research it looks like this homebrew stuff is very hit and miss if you don't have the right compressor. Will give Phil's idea a go and if not will ask the lads who aquabasted my mags in Stockport.
