975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:50 PM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Primo Axle conversion?
Author Topic: Primo Axle conversion?  (Read 931 times)
Offline Gary72
« on: February 14, 2015, 09:01 PM »
Got a Primo Pro hub this week, Bought because they dont come up that often. Only issue is its a 14mm axle and I want a 10mm.
Before I do an Ed and get the grinder out is they a way to swap axles maybe with something like a Primo Stock hub?
I do have a Sun Jabba the Hub with the axle already flatted. Am looking at swapping that over but looks like I would have to swap the collars over aswell.
And the bearings are different sizes side to side on the Jabba as its a flip/flop.
Would it be possible to machine down the Primo axle and re-thread to 10mm?
Offline VOIVOD
Re: Primo Axle conversion?
« Reply #1 on: February 14, 2015, 09:10 PM »
 :) Not a clue...but  think Primo might do a conversion for a Remix hub but the axle would prob be wrong as it is a cassette hub.I have a 36h/10mm Primo hub spare if it`s any use to you?
Offline Gary72
« Reply #2 on: February 14, 2015, 09:14 PM »
Is it a front or rear? Got any pics please.
And please dont tell me it's a large flange Primo Pro.
Offline Gary72
« Reply #3 on: February 15, 2015, 04:48 PM »
Well the axle swap with the Jabba hub wont work, Just took the axle out of the Primo and it has 4 bearings :shocked:
The axle doesnt seem to have a large hole drilled through it so might go down the machine and re-tap route.
Although i would like to use the original hardware. I do have a small flange Primo hub with 10mm axle will tap that out later and have a look.
Offline Munnyella
« Reply #4 on: February 15, 2015, 07:02 PM »
Take it to a machine shop and get it flatted properly.
Offline Gary72
« Reply #5 on: February 15, 2015, 07:05 PM »
It looks that is where I am heading.
Just took the axle out of my 10mm Primo small flange hub and that fooker has 6 bearings :wtf:
