975821 Posts in 138945 Topics by 6374 Members - Latest Member: Boults December 25, 2024, 06:31 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Drilled rims
Author Topic: Drilled rims  (Read 1720 times)
Drilled rims
« on: February 13, 2015, 04:57 PM »
Anyone took a drill to a set of Araya rims to make them pro class ?
Re: Drilled rims
« Reply #1 on: February 13, 2015, 05:24 PM »
Yes nick.....I think spen did some ages ago now
Re: Drilled rims
« Reply #2 on: February 13, 2015, 05:36 PM »
Far more common than you would imagine. A local engineer near me was doing a raft of em a while back for someone  ???
Offline Munnyella
Re: Drilled rims
« Reply #3 on: February 13, 2015, 06:04 PM »
Didn't drill araya's, but have done a set of cheapo single wall rims, easy enough if you set your self up properly I made a jig up from a bit of flat steel, 2 bots of rod that dropped through 2 spoke holes with a guide hole between the 2 rods, saved marking up for every hole.
Used a bit of stiff strapping from a pallet as rim tape.
Yeeee  Haaaa!!!
Must have been OK, Kappy bought them!!
MM
Offline CustardLips
Re: Drilled rims
« Reply #4 on: February 13, 2015, 06:05 PM »
This is something I've been thinking about recently.   :chin:
"WWG1WGA"
Offline john4130
Re: Drilled rims
« Reply #5 on: February 13, 2015, 06:24 PM »
i did the ones on my ammaco, copy 7x from porkchop.  :)
Re: Drilled rims
« Reply #6 on: February 13, 2015, 09:48 PM »
Done a few sets , came out great  8) fookin ballache marking all the holes out though  ::)
Re: Drilled rims
« Reply #7 on: February 13, 2015, 10:17 PM »
Nah Rob, it was PeterJ :daumenhoch:
I haven't got the patience :2funny:
Offline bobbbbsy
Re: Drilled rims
« Reply #8 on: February 13, 2015, 10:25 PM »
mattbloke did some . they came out really nice . matt nemo liddy.
Re: Drilled rims
« Reply #9 on: February 14, 2015, 09:31 AM »
Awesome, pm me your addy and I'll send a couple of sets  up to do then
Offline 58 delray
Re: Drilled rims
« Reply #10 on: February 18, 2015, 12:29 PM »
if you are going to drill out some rims to make pro-class rims dont use araya's.......araya's were never used to make pro-class rims bitd (except for the 24" version)
the rims were made in Taiwan for mongoose (by sumo i believe) and the holes were stamped out not drilled.
sumo's are still easy to get and a lot cheaper than araya's  ;)
the steel versions were made by CMC.
Offline torkerdude180
Re: Drilled rims
« Reply #11 on: February 19, 2015, 01:26 PM »
I did a set of sumo rim about 4 years ago, and had them powdered, looked sweet. 😉
THE TIGER
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Drilled rims
« Reply #12 on: February 19, 2015, 04:44 PM »
Problem solved...
Re: Drilled rims
« Reply #13 on: February 19, 2015, 04:58 PM »
 :LolLolLolLol:  Im upto my neck with with work and other stuff at the moment Nick otherwise i would have offered my services earlier  ;)
Re: Drilled rims
« Reply #14 on: February 19, 2015, 06:36 PM »
I took a drill to my willy... does that count?
https://soundcloud.com/superexstatic/radio-6-music-1
