975762 Posts in 138935 Topics by 6360 Members - Latest Member: TattooedYorkie October 01, 2024, 05:40 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Today's fettling
Author Topic: Today's fettling  (Read 745 times)
Offline Blacky
  • 720 back tap to fakie in
Today's fettling
« on: February 06, 2015, 07:32 PM »
Putting the brakes on my 20th anniversary  condor, had to grind the frame as their was a fault with the removable lugs that stopped the brake moving freely...gaaaaaaaaaay. Also wall mounting
same old same old
Offline egg
Re: Today's fettling
« Reply #1 on: February 07, 2015, 07:02 PM »
bit drastic grinding the frame! i had the same trouble when i put mine together.you just need to file the brass insert on the caliper as the lugs on the frame are low profile.
Offline Blacky
« Reply #2 on: February 07, 2015, 08:03 PM »
The white of the caliper around the brass was rubbing the frame if I filed the brass it would have sat lower and made it worse
same old same old
Offline fugazi
« Reply #3 on: February 07, 2015, 08:34 PM »
Weird, what brake are You running? Both of My frames & lugs have been fine, I've tried Odyssey Evo 2, Dia Compe AD 999, Primo E Brake & Revenge Industries & had no problems with any of them.
Offline Blacky
« Reply #4 on: February 07, 2015, 09:37 PM »
Ad999 the right side  was fine but the left side was a pig, how do you rate the 999 I love the look hopefully set up rite they will slam my face to the deck
same old same old
« Reply #5 on: February 08, 2015, 09:14 AM »
Lovely - I think I have one of those  :daumenhoch:
« Reply #6 on: February 08, 2015, 09:28 AM »
Offline fugazi
« Reply #7 on: February 08, 2015, 09:44 AM »
The 999 is a great brake, solid & easy to dial in  :daumenhoch:
Offline Blacky
« Reply #8 on: February 08, 2015, 09:55 AM »
same old same old
« Reply #9 on: February 08, 2015, 07:22 PM »
Nice Frames them.  :)
