975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 03:49 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  complete bottom bracket with spindle etc
Author Topic: complete bottom bracket with spindle etc  (Read 1441 times)
Offline paulb113
« on: January 31, 2015, 04:13 PM »
Is there a cheap complete set I could buy from somewhere?
I am going to try and get cheap new school frame and forks and built another bike with all the bits you have in the shed! I have a set of salt plus crank arms but some if the spindles I have seen are 25quid!
Thanks :daumenhoch:
Re: complete bottom bracket with spindle etc
« Reply #1 on: January 31, 2015, 05:35 PM »
When you say complete BB, in new school terms that's just bearings and washers normally.
Axles are normally designed with the arms in mind so will be a splined shaft with a certain number of splines.
Be better to get a whole set of counterfit cranks and BB from BMX city for £35
Offline paulb113
« Reply #2 on: January 31, 2015, 05:44 PM »
I thought they were universal :LolLolLolLol:
I had salt plus arms on my bike and changed to another make in chrome and they both fit.
Think the complete set sounds a better option :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #3 on: January 31, 2015, 08:41 PM »
was just luck the two crank sets used the same spindle
check the bottom bracket size of the frame too ,  ns frame will probably be either mid or spannish size , and you'll need a bb for the spindle size on the crank set usuallly 19mm,  but may be 22mm ,
 as Rob says BMXC counterfit cranks  sets  are real good value , the stark crank set is a steal  for the price, both have the option to buy with a bb  :daumenhoch:
« Last Edit: January 31, 2015, 08:45 PM by oldtired »
