975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 11:23 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How do you remove chrome?
Author Topic: How do you remove chrome?  (Read 779 times)
Offline generallee
« on: August 25, 2006, 08:50 PM »
Ive seen some lovely restos on here that were once chrome frames that have ended up painted/powdercoated... id like to do the same - but how do you get the chrome off? ANy help please!!
Offline phantom photon
Re: How do you remove chrome?
« Reply #1 on: August 25, 2006, 09:01 PM »
You don't have to remove the chrome. If you get it powdered the company you use will be able prep the surface prior to coating. Same applies for painting just a quick rub down to prime the surface :daumenhoch:
Offline generallee
« Reply #2 on: August 29, 2006, 09:35 PM »
have wet n dryed and sandpapered the chrome down to be as flat as poss - taking it to the powdercoaters tomorrow - think itll work?
Offline brass monkey!
« Reply #3 on: August 31, 2006, 03:54 PM »
get em to do a candy coat on top of the chrome, I think this is the technique Hutch used for their original fook oops on chrome frames !? hence a load of candy coated Hutch's !
that's if ya want candy !
otherwise its a good rub down  ;)
« Reply #4 on: August 31, 2006, 03:56 PM »
mine goes into costic then charged to release the chrome.
« Reply #5 on: August 31, 2006, 03:58 PM »
The correct way I believe  :daumenhoch:
« Reply #6 on: August 31, 2006, 04:11 PM »
Do you have to remove or prepare the chrome for powder, or can you powder over the top??
« Reply #7 on: August 31, 2006, 04:13 PM »
a good key will do then let it have it. :)
