975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 11:14 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spoke length required on 48's
Author Topic: spoke length required on 48's  (Read 526 times)
Offline oldskoolbmx
« on: December 30, 2014, 03:02 PM »
Hi, what length spokes do I need when using 48 hubs on 20" wheels please. :daumenhoch:
Offline Dannywhac
  • return of the whac
Re: spoke length required on 48's
« Reply #1 on: December 30, 2014, 10:10 PM »
In before the veins on Seans forehead show:
http://www.radbmx.co.uk/forum/index.php/topic,136816.0.html
Offline BMXOAP
« Reply #2 on: January 25, 2015, 12:44 PM »
Depending on what hub and rim you have will affect the length. Common is high flange hub and deep section rim. 182 mm rear and 184 front. The fronts are longer as the flanges are further apart. If the rims are deeper then knock off another 2mm 180 & 182 respectively. That's assuming a 4 cross lace pattern.
Hope this helps
