975653
Spencerkidd
July 07, 2024, 09:24 PM
Mid School ( Keep the faith )
Kong Fu US BB problems!! see picture
Topic: Kong Fu US BB problems!! see picture (Read 1279 times)
paulb113
Rockwalk
December 27, 2014, 03:58 PM »
I took my Kong Fu out on the Rad toy ride but the bottom bracket kept seizing up, it looks like it may have a bit missing? it looks like the main part on the left side screws on then its got a big nut on it but wondering if it should have two, one to lock it in place?
Will try and get a picture up later
Last Edit: January 01, 2015, 02:05 PM by paulb113
Gary72
Site Supporter
BMX Nerd
Re: Kong Fu US BB problems!!
December 27, 2014, 04:05 PM »
Is it a one piece crank?
If so it sounds like the locking nut is missing
paulb113
Rockwalk
Re: Kong Fu US BB problems!! see picture
January 01, 2015, 03:50 PM »
Not a 1 piece crank
oldtired
540 Air
Dirty Old Man
January 01, 2015, 06:45 PM »
doesn't look right that ,can you pull the crank arm off n get some pics , chains on backwards too
paulb113
Rockwalk
January 01, 2015, 06:55 PM »
I will see if I can get the arm off tomorrow, the part behind the arm seems to have a thread and tightens when its ridden, how could I change chain round on half link? should there be one pin that's loose?
oldtired
540 Air
Dirty Old Man
January 02, 2015, 12:24 AM »
chain will split like a normal chain with a link splitter , check the side plates on the links after though to make sure they're not deformed or cracked round the hole,this where half links will fail
if you haven't got any spare links leave it as is
should be ok , tis suposed to be run the other way round though
bobbbbsy
900 Air
January 02, 2015, 01:53 AM »
dump the half link chain. its been found out they stretch like mad. en vogue use traditional chains again now.
BADDH
Look Back
BMX
January 02, 2015, 09:33 AM »
Bring it round Paul I will repair that for you.
paulb113
Rockwalk
January 02, 2015, 04:37 PM »
Thanks Darren
shall I drop it off at the weekend?
paulb113
Rockwalk
January 22, 2015, 05:20 PM »
Bearings were wrecked!
paulb113
Rockwalk
January 22, 2015, 05:21 PM »
I got a new set of bearings
