975643 Posts in 138929 Topics by 6348 Members - Latest Member: Dannygee July 02, 2024, 09:57 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  How can you tell the difference between ...............................
Author Topic: How can you tell the difference between ...............................  (Read 2909 times)
.................... original 80s Landing Gear and the reissue LGs that Alans BMX were selling a few years back?   :-\ :daumenhoch:
Think reissues were only available in Chrome.  :-\
« Last Edit: November 12, 2014, 10:16 AM by BMX1973 »
quote from Brian Hays...
'The protos for Landing Gear started in 1979. They were released in 1980. For a very short time, there were no holes in the dropouts. They soon went to three holes in the dropouts through 1985 which encompasses all the unstamped 20" and the vertical stamped 20". In 86, SE went to a horizontal stamp, two holes and a much thicker dropout. All the 20" forks remained this way into the late 90's. When SE reappeared with the 2003 line, the 20" forks had no holes in them again BUT they still used the std horizontal stamp. Since then SE has used both the 2 hole and solid dropouts on 20" forks. '
Offline fischflo
first of all i believe the alans reissues were(/are?) the same as the prokchop reissues from 2010, and that both of these are stamped and have 4mm drops. the og LGs after 81/82 had about 3mm drops (1/8"; early landing gears even thinner).
edit:
compare:
http://www.alansbmx.com/5962/products/se_racing_landing_gear_1_inch_threaded_forks.aspx
http://bmxmuseum.com/forsale/5522
identcal pics (sic)         3 holers, both of em
« Last Edit: November 12, 2014, 01:07 PM by fischflo »
Offline fischflo
i meant planet BMX, not prokchop :teef:
Thanks for the replies chaps.  :)
So just to clarify all reissue would all be stamped SE in horizontal?  :-\
So would these be reissue?  :-\
http://www.ebay.co.uk/itm/Old-School-BMX-SE-Racing-Landing-Gear-1-Chrome-Forks-Skyway-Haro-PK-Ripper-/281493558289?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item418a52d411
Offline fischflo
i'm guessing , but i'd say no, as BRIAN HAYS says:
"In 94 or so they went to the 1 1/8" threadless design" :slayer:
So they are genuine 86 forks?  :-[
Offline 58 delray
something doesnt look right about them to me, the dropouts look too thick for a start....
I'd say 86 up to late 90s going on what Brian posted
2 holes, thick dropouts...
Or maybe they are much more recent!
« Last Edit: November 13, 2014, 09:36 AM by griff »
Offline 58 delray
just figured out what looks wrong, the dropout looks too low on the leg if you know what i mean, i have a few genuine sets at home, will get comparison pics for you tomorrow  :daumenhoch:
Re: How can you tell the difference between ...............................
« Reply #10 on: November 13, 2014, 11:31 AM »
Cheers :daumenhoch:
Offline fischflo
« Reply #11 on: November 13, 2014, 02:23 PM »
some more "86ers"
http://www.ebay.com/itm/1984-SE-Racing-531-Reynolds-Quadangle-BMX-Landing-Gear-Forks-US-made-EXCELLENT-/161442750302?pt=US_Cranksets&hash=item2596bcdf5e&nma=true&si=7Fe%252FAMM8Xm3RSSTDYnhqUFO8KaM%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
http://bmxmuseum.com/forums/viewtopic.php?id=586127
and if cyclepsych0 ere is right about this thick dropped forks being "original, U.S.-made, Landing Gears. Made from '95 - '99..cool", then i could imagine a set of 86-94ers to have drops as thick as the ones on the ebay set you posted, too. (edit: the missing link http://bmxmuseum.com/forums/viewtopic.php?id=448567  :crazy2:)
end of guesses, time for the forked folks to errm ....confirm :LolLolLolLol:
« Last Edit: November 13, 2014, 06:34 PM by fischflo »
« Reply #12 on: November 13, 2014, 06:14 PM »
Thanks  :daumenhoch:
some more "86ers"
