975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 11:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  any one ever laser copied onto chrome vynil ?
Author Topic: any one ever laser copied onto chrome vynil ?  (Read 563 times)
steve
« on: August 23, 2006, 11:20 PM »
-then sealed with clear sticky?
Offline Del
  • Re-living my youth!
Re: any one ever laser copied onto chrome vynil ?
« Reply #1 on: August 24, 2006, 06:10 PM »
i cant answer your qustion but can you laser print onto normal vinyl sheets? ie white or clear?
macmark
« Reply #2 on: August 24, 2006, 06:15 PM »
It depends a lot on what type of vinyl and also what type of laser printer/copier you have. Some vinyls will just get stuck to the feed mechanism of your printer/copier and make one hell of a mess. Other vinyls will go through no problem but the toner might not adheer to the surface and will wipe straight off. It could end up being a costly exercise. What is it you're trying to achieve?
Mark
