975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 19, 2024, 02:06 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Twin chain/drive setups?
Author Topic: Twin chain/drive setups?  (Read 1019 times)
« on: October 25, 2014, 03:36 PM »
Seen this done a few times and just wondering if anyone knows of suitable hub suggestions besides a clem twin. Can i just use any old flip flop with the right freewheel?
At the moment im thinking along the lines of machining a secondary thread on the non drive side of a suzue hub  :D
Offline john4130
Re: Twin chain/drive setups?
« Reply #1 on: October 25, 2014, 04:22 PM »
you would need a left hand drive freewheel. and a flip flop hub wont be any use as when you pedal the left side would just unscrew.
« Reply #2 on: October 25, 2014, 05:06 PM »
You will need a hub with both left and right hand drive threads.  Which shouldn't be too hard to find these days.
You will also need either a left hand crank arm (with spider etc) or re-thread a right hand crank arm.
« Reply #3 on: October 25, 2014, 05:11 PM »
What about 2 old school right hand crank arms (square spindle) and 2 right hand pedals  :D
Offline snoopy72
« Reply #4 on: October 25, 2014, 05:14 PM »
Unless you loctite the thread the left hand pedal will come loose all the time
« Reply #5 on: October 25, 2014, 05:15 PM »
Problem is that running a right hand crank arm with right thread pedal on the left it will unscrew the pedal.
What you can do is look at tandem crank set ups as the rear rider has both left and right drive crank arms.
« Reply #6 on: October 25, 2014, 05:44 PM »
Oh course! Not thinking straight today  :(
thread lock?  :-[
Offline snoopy72
« Reply #7 on: October 25, 2014, 05:55 PM »
loctite 243
« Reply #8 on: October 25, 2014, 06:00 PM »
Do it properly and either rethread or find a classic left hand drive crank arm.
« Reply #9 on: October 25, 2014, 06:15 PM »
Was only joking about the thread lock  :)
Would deffo do it properly. Been seeing alot of nice orphan drive side crank arms recently and it got me thinking  :chin:
Offline chubby
  • Needs Pegs
« Reply #10 on: October 25, 2014, 06:23 PM »
I know where there's a spare southpaw Clint  :whistle:
« Reply #11 on: October 25, 2014, 06:26 PM »
 :LolLolLolLol: yep my photographic memory of your ground sheet at MK had already woven it into the mix  >:(
Offline Dannywhac
  • return of the whac
« Reply #12 on: October 26, 2014, 01:19 AM »
Or - buy two 43/44 tooth spline drive sprockets and slap em on some Profile or similar cranks. No need for re-threading, but they ain't cheap Clint  :daumenhoch:
Offline chubby
  • Needs Pegs
« Reply #13 on: October 26, 2014, 09:56 AM »
Best find the bugger then  :LolLolLolLol:
Offline Gary72
« Reply #14 on: October 26, 2014, 02:48 PM »
Does it have to be old school. Cant remember who but someone makes a hub where you can take the driver out and put it in the other side. Think it is called bi-drive or something. Lots of newer cranks have both arms with a sprocket bolt.
Just a thought
