975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 08:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bolt cleaning question
Author Topic: bolt cleaning question  (Read 756 times)
Offline oldskoolbmx
« on: September 13, 2014, 10:43 AM »
Can not find one of these locally or on ebay, nut size is 11mm, length including head is 30mm, head diameter 11mm, does anybody have one? If not which is the best way to get rid of the rust in all the hard to reach places, and to polish it up?
Thanks
John
Re: bolt cleaning question
« Reply #1 on: September 13, 2014, 10:47 AM »
What's it from John, seat clamp?
You could try leaving it in brown sauce overnight?
« Reply #2 on: September 13, 2014, 10:55 AM »
Lemon juice for a day or so
Then give it a brush
Offline oldskoolbmx
« Reply #3 on: September 13, 2014, 12:41 PM »
Yes Dan it's a seat clamp bolt, would like to keep this rather than use a none original part
« Reply #4 on: September 13, 2014, 01:08 PM »
Had this problem myself, citric acid or lemon juice, weak solution to remove the rust and a good rinse in water.  Then use gun blue to bring the black back.
Offline Steve P
« Reply #5 on: September 14, 2014, 04:07 PM »
I always polish stem and seat clamp bolts on a bench wheel then clean inside the hexagon with a wire brush
Gun blue is always a good trick to restore the black like Marty said  :daumenhoch:
« Reply #6 on: September 14, 2014, 04:27 PM »
A tip I got from you Steve a long time ago!
Offline Steve P
« Reply #7 on: September 14, 2014, 05:19 PM »
It's one of the best resto tricks in the book Marty  :4_17_5:
