975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  The best thing to help grips on with.........
Author Topic: The best thing to help grips on with.........  (Read 1921 times)
Offline McQUEEN
  • I left it in the garden......
« on: September 12, 2014, 09:51 AM »
 I forgot this one from bitd but the easiest way to get a set of grips on is to use hair spray - I struggled last weekend to get these Oakleys on and last night, after a trip to Boots and a big smile from the sales assistant (I was thinking that she thinks I'm hot / she was thinking no way he uses hairspray, he needs regain), these slipped on it about 15 seconds each. Stoked.
When I was born, the world was a far simpler place.
It was all just cops and robbers.
And BMX.
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: The best thing to help grips on with.........
« Reply #1 on: September 12, 2014, 10:10 AM »
An oldie but a goodie bud. Hairspray on, WD40 off.
It doesn't work with all hairsprays though, if you buy some of the new "strong" stuff your grips can stick like glue in seconds...
« Reply #2 on: September 12, 2014, 02:29 PM »
WD40 to put on and take off has never failed
Offline Skid
« Reply #3 on: September 12, 2014, 05:07 PM »
Water. To take them off, to put them on, costs less than all the above.
« Reply #4 on: September 12, 2014, 06:04 PM »
Before I put them on I always put them in boiling water first. Although remember to put some gloves on when fitting. I do the same to take them off, soak the bar end in boiling water. Then they just pull off.  :daumenhoch:
Offline McQUEEN
« Reply #5 on: September 12, 2014, 08:35 PM »
Just found a problem with the hairspray........the wife came home and could smell it and wondered who I'd had in the house. She really believes these bikes are an obsession when she found out I'd actually bought hairspray! :LolLolLolLol:
And BMX.
Offline Skid
« Reply #6 on: September 13, 2014, 02:08 AM »
« Reply #7 on: September 13, 2014, 02:15 AM »
Yep X2 on that. Make a brew at the same time they are soaking in the boiling water :daumenhoch:
Offline Gary72
« Reply #8 on: September 13, 2014, 08:25 AM »
I normally use cable ties, Slide 3 or 4 into the end slide onto bars and using pliers pull cable ties out.
But last set I did I used brake cleaner.
Offline willo73
« Reply #9 on: September 13, 2014, 08:51 AM »
White spirit on (have to be quick tho!), soak in jug of boiling water off
« Reply #10 on: September 13, 2014, 09:03 AM »
Isopropanol alcohol, I 'borrow' it from work, slides on then evaporates.
Offline bmxband1t77
  • '77 a good year (Star Wars-Punk) but not my DOB.
« Reply #11 on: September 16, 2014, 01:14 AM »
I've always used hairspray. On inside of grip and round bar ends. Important to let it go tacky first, then quickly twist the grips on and even them up. Overnight it dries fast, no slip. As it's mostly water soluble it should come off squirting hot water up ya grips....ooooh. Sounds rude!
I tried the cable ties and got in a mess. I'm dubious spraying lubricant is a good idea, worst thing ever yanking ya bars to find you have grips in your hands but ya bikes wayyyy over there?!?!
IPA I would think could potentially harm the rubber making it brittle? Dunno. Just way my brains wired.
Sent from my iThingy using Tapatalk
Offline Glynnyboy
« Reply #12 on: September 16, 2014, 03:47 PM »
I used to use hair lacquer too but raced in the rain a couple of year back & the grip started to loosen when they got wet through.
Same thing happened to my daughter when she was out on her Cali in the rain but the grip came off in her hand.
Since then I use car lacquer. It works pretty much the same but is water proof.
Getting them off is just a screw driver down to crack the seal.
Offline CustardLips
« Reply #13 on: September 16, 2014, 03:54 PM »
WD40.... wax on wax off.  :slayer:
"WWG1WGA"
« Reply #14 on: September 16, 2014, 04:01 PM »
« Reply #15 on: September 16, 2014, 04:37 PM »
surely using wd40 to put your grips would make them slip off all the time...   ???
I've always used washing up water (same amount as you would put in a bowl to wash up in),  then exactly the same amount to take them off...
Offline snoopy72
« Reply #16 on: September 16, 2014, 06:27 PM »
Wurth HSS 2000 to fit
Wurth 2040 and a thin screwdriver to remove
« Reply #17 on: September 16, 2014, 08:17 PM »
WD40 works a treat for putting on and getting off  :daumenhoch:
Offline Gnarlyscoots
  • BANNED
« Reply #18 on: September 16, 2014, 08:32 PM »
Water on, water off. If no can find water, use spit and wee wee  :daumenhoch:
BANNED
« Reply #19 on: September 16, 2014, 08:48 PM »
I used to use that all the time when I worked in the PCB industry. We would wait for one of the lads to go for a shit, allow him to get comfy, then flood the cubicle with it by tipping 5L under the bog door.  :D
« Last Edit: September 16, 2014, 09:12 PM by Retrodan72 »
Offline Devilock
« Reply #20 on: September 16, 2014, 09:09 PM »
This.
  • Andy
« Reply #21 on: September 16, 2014, 09:31 PM »
This.
Not the reply I expected from you Rich. I was hoping for something sordid...
Offline Devilock
« Reply #22 on: September 17, 2014, 12:26 AM »
This.
I'm fighting the demons. My GP said fresh air & sprouts will end this possession.
Offline VOIVOD
« Reply #23 on: September 17, 2014, 01:38 AM »
Don`t fook about with any of that-the joys of ODI Lock-Ons:)  When I use regular grips I use a couple of big zip ties and just slide the grips over them then pull  the ties out.
« Last Edit: September 17, 2014, 01:56 AM by VOIVOD »
Offline monteryroom
« Reply #24 on: September 30, 2014, 08:10 AM »
i don't know if they sell Lynx over there? Always use that and leave them overnight.
