975755
TattooedYorkie
September 21, 2024, 01:42 PM
dia comp brake cable clamp strap question
Topic: dia comp brake cable clamp strap question (Read 570 times)
oldskoolbmx
Curb Endo
September 06, 2014, 08:12 PM »
http://www.ebay.co.uk/itm/Dia-Compe-Brake-Cable-Clamp-Blue-Oldschool-BMX-Fixie-New-Free-UK-Delivery-/261305511491?var=
Hi, I measured my top tube on my frame which measures about 90mm circumference, these brake cable clamp straps I want which are in the link above for you to see only go to 31.8mm, which is tiny so how the hell do these fit??? It might be a daft question but this is my first build
Thanks
John
Last Edit: September 06, 2014, 09:34 PM by oldskoolbmx
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Re: dia comp brake clamp question
September 06, 2014, 08:49 PM »
John, what are you running with a 90mm diameter Top tube
Gary72
Site Supporter
BMX Nerd
Re: dia comp brake cable clamp strap question
September 06, 2014, 09:39 PM »
Pi Is your friend
john4130
Look Back
September 07, 2014, 10:21 AM »
90mm circumference means a 28.6 diameter tube.
oldskoolbmx
Curb Endo
September 07, 2014, 06:38 PM »
Thanks alot lads
