975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 12:34 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  opc's on midschool & now general morales build thread *** FINALLY FINISHED ***
Author Topic: opc's on midschool & now general morales build thread *** FINALLY FINISHED ***  (Read 24590 times)
0 Members and 13 Guests are viewing this topic.
Offline chubby
  • Needs Pegs
Awsome
If I di end up going with the Bfr wheels from bmx city hopefully they'll build em up 😉
If you come across owt else that I need please give mee a shout Dan 👍
sent from an mk shitter
Offline nosepickben
;D
Dead right. Primo axles are 22mm.
Right so a funky a funk 36-39 sprocket, i need 14mm rear hub for the morales so will I be able to use the larger 30mm rear cog ??? Acs or odyssey 13-15t
Have I finally got it in my thick head right  :LolLolLolLol:
A 14mm axled hub may have either freewheel thread size. 30mm thread is the smaller of the two and will take 13-15t free wheels. If you want to run a 36, go for a 13 rear. If you run 39 then  use a 14 rear.
Offline chubby
  • Needs Pegs
Wotcha midschoolers primo powerbite have arrived from wini , not ever having 3pc before I'm bit stumped on the bb situation  :-[
The morales had a normal loose bearing bb on the dna cranks which all screwed together same as a normal opc
Need a sealed bb suitable for the primo any ideas would be great. Links to the right thing even better  :LolLolLolLol:
Cheers fellas  :-*
Offline Dannywhac
  • return of the whac
Hold off again me old mukka - I might have a spare US Primo BB as on a bike I got the Powerbite cranks arms were fooked. Will have a butchers when I look for that hub  :daumenhoch:
If I fail, cheapest I could find:
http://www.ebay.co.uk/itm/like/141360634600?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108
Offline chubby
  • Needs Pegs
Cheers Dan, Spanish, usa, mid bb's !!!!!! All too much for me today 😝
Offline chubby
  • Needs Pegs
Help time again midschool kids  :LolLolLolLol:
Scored a nice dinky stem earlier on it's a 1 1/8th  "nono" gonna need a 1" conversion shaft for the kore forks. Really need one with a potts bolt, had a poke about & seem to be plenty of normal ones with a recessed allen head bolt fixing but failed to find a potts one so far......
Any of you guys know of a potts modded conversion shaft or a potts bolt that can be used with one ???
At a push I've got one of them universal potts bolt (hex head) that I could cut down & use a washer on the head but it sounds a bit bodgy (not that it's worried me before  :whistle: )
Thanks yet again fellas & I promise to stop bothering you all soon  :LolLolLolLol:
Rich, i imagine those convertors would be easy to bore out for a potts mod bolt   :)
Offline chubby
  • Needs Pegs
Forgot the fookin things were bigger  :whistle:
Offline bobbbbsy
opc s came back at a point after being frowned upon for years. very much a mid skool thing . even generic bikes into early 00s..
Noooooo they didn't - flatlanders used em, and generic bikes throughout time used em (and still do) but the majority of the mid to late 90's every bugger that rode anything other than a paper delivery round had a 3 piece crank. They became cheap enough by then for peeps to afford.
well just check out loads of midschool completes , mongoose , gt , dyno -etc etc .. i never said good bikes or pimped out bikes. paperboys are RAD  :slayer:
« Last Edit: September 06, 2014, 05:15 AM by bobbbbsy »
Offline brakedancer
why are you not sticking a normal shafted stem in it ...
what your doing sounds a bit bodgy ... :shocked:
no offence ,,, :)
Offline chubby
  • Needs Pegs
no offence ,,, :)
None taken mr Dancer
Didn't like most 9f the 1"mid stems & ended up going for something really rare & different  ;D in 1 18th
Just cos I like the look of it  :whistle:
« Last Edit: September 06, 2014, 06:50 PM by chubby »
Offline brakedancer
ok dude  :coolsmiley:
so when do you get the frame back....?
maybe a profile chainring if you get stuck there quite universal..... :daumenhoch:
Offline chubby
  • Needs Pegs
When uncy Dans sorted it 😉😉
Do need a chainwheel 36-39t
If you've got one going 👍
Offline chubby
  • Needs Pegs
Offline Dannywhac
Agreed - looks like it's had a phat chain on it :)
Profile Whippets more of a street/dirt sprocket tbh - W@nkstanleys do a Profile SS 39T for 28 quid.
Offline chubby
  • Needs Pegs
Best look wehn soberer
Offline gary4130
i think you should put a freecoaster on the back wheel mate -it's a flat bike afterall -then its going to be easier for the gearing -as there loads of cogs available in different sizes  ;)
Offline chubby
  • Needs Pegs
i think you should put a freecoster on the back wheel mate -it's a flat bike afterall -then its going to be easier for the gearing -as there loads of cogs available in different sizes  ;)
Something else to confuse me  :LolLolLolLol:
I'll have a look into it bud  :daumenhoch:
Offline chubby
  • Needs Pegs
Just sorted the wheels from Dan @ bmxcity, really helpful bloke & ended up with the BFR'S with stainless spokes & sealed prolite bubs ???
14t freewheel & blingy chrome chain delivered for 60ish notes  :daumenhoch:
May not be for the purists amongst you but gone for things I like the look of more than anything else  :whistle:
Viynal arrived from the states for the decals & is off to Delboy, frames with Dan, tyres still at clints  :LolLolLolLol:
Need chrome gyro, rear brake cos I fancy a 990 or something odder (chrome) still need a groovy chainwheel ,some of that holographic/cosmic brake cable & a 1 1/8th to 1" stem adapter  :chin:
So come on guy's raid your stashes & hook me up
Ps nows a good time as I'm drinking  :slayer:
« Last Edit: September 09, 2014, 05:34 PM by chubby »
Ooops sorry bud, forgot all about those tyres. Will get em out to you  :LolLolLolLol:
Offline chubby
  • Needs Pegs
:LolLolLolLol:  :LolLolLolLol:
Whenever Clint  :-*
Offline chubby
  • Needs Pegs
 forgot I'm still struggling for big fook off pegs too. Madder the better  :daumenhoch:
« Last Edit: September 10, 2014, 11:03 AM by chubby »
Offline chubby
  • Needs Pegs
Del came up trumps again !!!!!
Think they look fookin ace 😉😉
Looking good Rich  8)
