Is it only a cats whisker off going on or quite a margin. If the former, sit the ring on a hot plate or stove so it expands slightly then seat it square and tap down with a long section of tube which either matches the diameter of the inner section of ring or the outer. Dont hit it around the bearing curved section... if that makes sense
That's the bearing race that fits onto the bottom of the stearer tube. It doesn't screw on... it needs tw@ting on with a hammer. I use this A piece of (I think it's 25mm ) copper pipe and keep belting it till it's on. Oh, put a bit of grease or vaseline around the raised part of the tube to ease it in/on... you know the score.
[ Attachment: You are not allowed to view attachments ] Sorry forgot to post forks
Quote from: CustardLips on August 20, 2014, 05:02 PMThat's the bearing race that fits onto the bottom of the stearer tube. It doesn't screw on... it needs tw@ting on with a hammer. I use this A piece of (I think it's 25mm ) copper pipe and keep belting it till it's on. Oh, put a bit of grease or vaseline around the raised part of the tube to ease it in/on... you know the score. I'd turn it upside down then put wood on the bottom of the steer tube and twat that so the copper tube is against the ground, doing it the way it is in the photo runs the risk of damaging the fork drop outs if that makes any sense
