975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 07:57 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Lacing pro-class question?
Author Topic: Lacing pro-class question?  (Read 925 times)
Offline hokuspokus74
« on: August 13, 2014, 09:10 PM »
I have got the back wheel laced to small hub 194mm 4 cross....what size is it for a large suzue hub laced 4 cross,just cant find anything to measure it with et this is why am asking or what pattern can i use on large hub?
cheers :daumenhoch:
Offline RAD4BMX
Re: Lacing pro-class question?
« Reply #1 on: August 13, 2014, 09:36 PM »
used this last week so fresh in my mind.
http://www.radbmx.co.uk/forum/index.php/topic,136816.0.html
Stidds has an excellent wheel build guide too.  :daumenhoch:
« Reply #2 on: August 13, 2014, 09:38 PM »
I think off the top of my head its 189mm u need . But check Stidds spoke calculator in the stickies above fella  :daumenhoch:
« Reply #3 on: August 13, 2014, 10:09 PM »
Yeah i had used stidds calculator in the past was spot on  :daumenhoch: ....was needing an answer just cant find anything to measure the hubs etc with ive misplaced them,so 189mm hmm will need to find ones,cheers guys ;)
Offline CustardLips
« Reply #4 on: August 13, 2014, 10:16 PM »
He has... use it every time.  :daumenhoch:
"WWG1WGA"
« Reply #5 on: August 13, 2014, 10:42 PM »
ive used it its really accurate,but need to be sure on the spoke size that anyone can tell me,just i have loads of spokes in the workshop,but might need to order the rite size  :daumenhoch:
« Reply #6 on: August 14, 2014, 09:55 AM »
ok found the calipers to measure the hubs etc,ok when i calculate for the size of spokes it says 197mm for 3x and 4x is 186 this is on the large flange suzue hub,how can i go about using 194mm spokes?
Offline fischflo
« Reply #7 on: August 14, 2014, 11:15 AM »
If the hubs are Suzue small flange size then 194mm with a 4 cross lace , if they are large flange 184mm ( 3 cross lace ) or 192mm with a 4 cross lace  :daumenhoch:
I will double check later but ideally like Jongoose ^ says above we need to know what hubs they are  ;)
 :laugh:
« Reply #8 on: August 14, 2014, 11:49 AM »
It just says suzue on it so here is a pic of it,would i get away using 194mm
Offline fischflo
« Reply #9 on: August 14, 2014, 12:33 PM »
don't think so, they look large, high flange to me
think the required small flange would be about 50mm edge to edge?   ..at least that's what boba's SR hub measured (in the link i posted).
« Reply #10 on: August 14, 2014, 12:54 PM »
yeah there large mate so thats a no to the 194mm,i may strip the other wheel i built and build it with just small hubs :-\
« Reply #11 on: August 14, 2014, 06:49 PM »
Found 185mm spokes will they do on them large hubs 3x or what pattern will do :daumenhoch:
« Reply #12 on: August 14, 2014, 08:37 PM »
rite i used the spoke calculator it came up with 185mm 3x i have started on the outbound ones got a few in now there really short,will 194mm not work.... "help"
Offline dannyrobo
« Reply #13 on: August 14, 2014, 09:13 PM »
ive fitted high flange suzue front hub to pro class and i used 194mm 4x  :daumenhoch:
« Last Edit: August 22, 2014, 10:53 AM by dannyrobo »
« Reply #14 on: August 14, 2014, 09:43 PM »
cheers danny,after me just stripping another rim to get 189-190mm spokes,good 194mm wish someone had off told me earlier,your a life saver  :daumenhoch: :daumenhoch: :daumenhoch:
Offline fischflo
« Reply #15 on: August 14, 2014, 10:10 PM »
sorry, man. just ignore my posts in the future ;D
....the 8mm difference between danny and the calculator result is strange, though :chin:
« Reply #16 on: August 14, 2014, 10:42 PM »
LOL :crazy2: ive fooking gave up on it when i go to do the 4x the spokes to short lol yet i laced the back rim on small hub no problem but this is doing my fookin head in,will give it another blast after work tomorrow,if the spokes are to long and they poke through the nipples i'll just grind them off  :daumenhoch:
Offline bigfatolly
« Reply #17 on: August 15, 2014, 10:14 PM »
That's what I did with some Zeds,some of the spokes were too long so I ground them off with the Dremel....
« Reply #18 on: August 17, 2014, 12:33 PM »
right am going to do a set of z rims now on large flange sr hubs will 186mm spokes be ok 3 x ?
« Reply #19 on: August 22, 2014, 09:33 AM »
rite am going to lace a set of araya 7x to large flange hubs its 186mm 4x,but can i use 184 with long nipples?
Offline dannyrobo
« Reply #20 on: August 22, 2014, 10:45 AM »
184mm 3x will be fine for 7x  on high flange hubs  :daumenhoch:
« Reply #21 on: August 22, 2014, 01:41 PM »
Good man dan just am never to sure on the right size of spokes coz i seen me putting the wrong thing into the calculator before and started too lace it and it was all higgelty piggelty :D
