975825 Posts in 138946 Topics by 6376 Members - Latest Member: The Carrot Cruncher December 28, 2024, 09:46 AM
RADBMX.CO.UK  |  Market Place  |  Jumble Sale  |  Mondraker Dune full sus Trail/Enduro mountain bike .............
Author Topic: Mondraker Dune full sus Trail/Enduro mountain bike .............  (Read 836 times)
Another bike is on order so this one needs to go .
Mondraker Dune , size large ( these come up slightly small so this is more like a medium , I'm about 5'10"- 5'11" ) . I bought it late 2011 as secondhand but not often used . It had suspension bushes done straight away and was also converted to twin front ring from triple , it uses a Gamut bashguard and E13 dual chain device ( it could be changed back to triple if you wanted ) .
It was used once in 2011 at Forest of Dean then twice in 2012 at FoD also ( that's three times in total ! , I had a Ti hardtail which was used week in week out locally ) . In 2013 I damaged my knee in the January out on an XC ride on my hardtail and didn't ride again until Oct 2013 . Since Oct 2013 I've used it as my only bike ( hardtail was sold in 2013 ) but have had a back problem this year so not ridden regularly . It's been used for XC locally or trail riding up at Woburn .
The forks and shock get lubed after every ride to keep the seals supple . New Sram BB , chain and cassette fitted a few weeks ago .
It rides really nice and has some very nice upgrades , standard spec below and upgrades also in brackets ..............
 Frame:  Dune Stealth FT alloy Zero Suspension System with 160mm travel
Rear Shock:  Fox Float R XV Boost Valve 215×63.5mm
Fork:  Rock Shox Lyric SA Tapered with 160mm travel
Front Derailleur:  Shimano SLX FD M-661D Direct mount
Rear Derailleur:  Sram X9 Medium cage
Shifters:  Sram Trigger X-7
Chainset:  Truvativ Firex 3.1
Chainrings:  44/32/22 tooth Chainrings ( now twin ring with gamut bash & e13 device )
Bottom Bracket:  Truvativ GXP ( new Sram/Truvativ BB just fitted )
Cassette:  Sram PG-950 11-32 tooth 9 speed ( New Sram cassette just fitted )
Chain:  Sram PC-951 9 speed ( new Sram chain just fitted )
Pedals:  Onoff Mtb Spd  ( Burgtec MK2 Penthouse flats )
Front Brake:  Formula K18 with 180mm Rotor
Rear Brake:  Formula K18 with 180mm Rotor
Brake Levers:  Formula K18
Handlebars:  Onoff AM 31.8mm 680mm  ( Funn 786 wide DH riser bars fitted )
Stem:  Onoff AM 31.8mm  ( Hope 50mm stem fitted )
Headset:  Gravity SX-Pro Integrated 1-1/8 upper 1/5 Bottom
Grips:  Onoff Diamond close end  ( Intense ODI lock ons fitted )
Rims:  Onoff Draw wheelset
Front Hub:  Onoff Disc DH 20mm
Rear Hub:  Onoff Disc Quick Release
Spokes:  CN Stainless
Front Tyre:  ITS-Mondraker System 4 2.25  ( will also come with nearly new Conti Baron )
Rear Tyre:  ITS-Mondraker System 4 2.25  (  will also come with nearly new Conti Baron )
Saddle:  M-Decline  ( SDG Bel Air fitted )
Seatpost:  Onoff Notion 0-R 31.6mm  ( Rockshox Reverb fitted )
Pics .............
It's looked after well and kept clean , it lives in my hallway !! . Will not come with bottle cage .
I could bring it to MK but don't want to post it really , I'm in Buckingham MK18 postcode , approx. 15mins from the M40 and 20mins from the M1 .
As new they were £2200.00 , a host of upgrades so a steal at £699.00 .
Re: Mondraker Dune full sus Trail/Enduro mountain bike .............
« Reply #1 on: August 02, 2014, 12:38 AM »
SOLD
