975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 03:21 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Best way to remove coloured brake rub from White Tuffs ????
Author Topic: Best way to remove coloured brake rub from White Tuffs ????  (Read 1638 times)
Offline Funkyworm
Ok so i picked up a set of new WHITE tuffs the other week,  the guy has only used them once but with BLACK brake pads.
Anyone know a quick easy way to remove this without marking up the wheels ?
Thanks in advance
Offline Munnyella
Re: Best way to remove coloured brake rub from White Tuffs ????
« Reply #1 on: June 28, 2014, 09:43 PM »
you could try T cut or similar, but I reckon careful application of a razor blade is the easy way!!
MM
Offline Funkyworm
« Reply #2 on: June 28, 2014, 09:58 PM »
MM
Yeah I've got the razor blade out but think I'll wait for daylight to try it properly.... Scotch brite pad maybe ???
« Reply #3 on: June 28, 2014, 10:15 PM »
Toothbrush and bleach  :-\
Offline bigfatolly
« Reply #4 on: June 28, 2014, 11:22 PM »
Stanley knife blade,hold it with both hands and kind of scrape it towards you with the blade at a slight angle :daumenhoch:
Offline Jt
« Reply #6 on: June 29, 2014, 01:48 PM »
One of them white magic sponges will do it...
« Reply #7 on: June 29, 2014, 08:04 PM »
Its a proper cynt of a job in all honesty, anyone that says 'a bit of brake rub but easily sorted' has never done it themselves. I hate it and has put me off buying old tuffs in the past
Offline chubby
  • Needs Pegs
« Reply #8 on: June 30, 2014, 09:30 PM »
Cif & 1 one of those curly metal pan scouring things Cal, scotchbrite works too bud I used purple on some zytecs recently  :daumenhoch:
« Reply #9 on: July 01, 2014, 12:17 AM »
Tippex  :daumenhoch:
Offline maca
« Reply #10 on: July 01, 2014, 07:31 PM »
I used Boiling water and did a bit at a time, the hot water soffens the rubber left behind by the brakes and then used a razor for the stubbon bits.
Offline benno
« Reply #11 on: July 01, 2014, 07:50 PM »
orbital sander, check my z rim resto thread, thats what i used
It comes out of the ground!
Offline Steve P
« Reply #12 on: July 23, 2014, 12:34 PM »
Cream cleanser (Cif) on a kitchen scotch brite sponge ... works every time  :daumenhoch:
« Reply #13 on: July 23, 2014, 12:51 PM »
Craft knife and fine paper.
Offline fischflo
« Reply #14 on: July 23, 2014, 06:50 PM »
dye tuffs in colour of the brake rub
Offline Devilock
« Reply #15 on: July 23, 2014, 07:03 PM »
 ;D
Offline Rabdul06
« Reply #16 on: August 06, 2014, 09:33 PM »
   Stanley knife blade and drag it towards you keeping it level. Boring job but easy enough. Then go over it all with a scotchbrite scrubby pad thing...
Offline Gnarlyscoots
  • BANNED
« Reply #17 on: August 06, 2014, 09:40 PM »
Bolt the wheel in the frame or fork, lay the blade in the rim and run the wheel away from the blade edge while pressing firmly.
You will get a near finish to the rim and it's not tedious this way either   :daumenhoch:
BANNED
Offline deeman
« Reply #18 on: August 09, 2014, 08:37 PM »
I use wet n dry. start with 180 grit and work up to 1200, then a bit of t cut. Tedious but works  :daumenhoch:
