975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 08:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spoke size
Author Topic: spoke size  (Read 537 times)
spoke size
« on: June 28, 2014, 09:19 AM »
lacing Araya 48s to Peregrine semi pros ... with a twist ( in the spoke )
thought 187s would be close enough put they are miles out ... looking at getting 183s?
what do we think  :)
Offline john4130
Re: spoke size
« Reply #1 on: June 28, 2014, 05:54 PM »
i've done this before and just used the correct size spoke for building it up normal, i dont think you need longer ones just because it has a twist in it.  the best way i found to do it is build the wheel as normal leaving all the spokes loose then go around it removing 2 spoke nipples and twisting the spokes then replacing the nipples.
Offline nosepickben
Re: spoke size
« Reply #2 on: June 28, 2014, 06:09 PM »
Stop making gay wheels
Offline GavinDavis
Re: spoke size
« Reply #3 on: June 28, 2014, 07:59 PM »
Just measured the ones that i bought from Mark @ Retrospect and theyre coming in at 182mm.  Im pretty sure that when i bought them he listed them as 186mm??
Hopefully they'll be ok for a twisty build when i finally manage to get the right bits  :'(
Re: spoke size
« Reply #4 on: June 30, 2014, 06:20 AM »
cheers John ... the build is not a probelm... I'm well practised as I keep getting the wrong size!
Gav - I reckon an actual length of 182 would be spot on - I'm going for 183 and seeing how it comes out.
Will keep you informed.
Ben - your Yoda-esque advice is always refreshing  :surprise:
