975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 02:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  any tips on lowing my seat post both post and frame been powercoated its tight
Author Topic: any tips on lowing my seat post both post and frame been powercoated its tight  (Read 671 times)
Offline Los1969
still needs to go down about 2 inches have sprayed it and hit with a hammer lol or do I need to turn it with seat on? cheers los
Can you get it back out now you've hit it down?
  • Andy
I've found out that a build up of rust is quite a common problem. I usually tape a piece of sandpaper around a cylindrical piece of dowling wood, and lightly sand the inner part of the seat tube. I then give it a clean with some wd40 on a rag wrapped around the piece of wood again
Offline Los1969
Cheers don't know yet  will give it a try, thanks also dttdb
