975841 Posts in 138948 Topics by 6379 Members - Latest Member: McChippy72 January 16, 2025, 06:37 AM
RADBMX.CO.UK  |  Market Place  |  Jumble Sale  |  Spare building stuff
Author Topic: Spare building stuff  (Read 957 times)
Offline poolysheriff
« on: June 22, 2014, 05:04 PM »
Spare stuff left from a few houses i have just renovated , prices are not posted , ideally someone might pick up at MK save posting , loads of other random stuff i,m on going through
3 boxed Mira shower heads , Response in white
same as this one
http://www.ebay.co.uk/itm/151006001546'ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
£20 for all three
UAP 70mm nickel euro door cylinders
same ones on ebay
http://www.ebay.co.uk/itm/UAP-Zero-Lift-Anti-Snap-Anti-Bump-Door-Euro-Cylinder-High-Security-/281057502582?pt=UK_HaG_Lock_Safes_GL&var=&hash=item4170552576
£50 full box of 10
Bosch auger wood drill bit 25mm x 160mm
same one on ebay
http://www.ebay.co.uk/itm/Bosch-25mm-X-235mm-Auger-/221441751086?pt=UK_Home_Garden_PowerTools_SM&hash=item338ef4f82e
£10
McAlpine straight toilet pan outlet connector
same ones on ebay
http://www.ebay.co.uk/itm/McAlpine-Straight-Toilet-Pan-Outlet-Connector-WC-CON1-/261188867830?pt=UK_DIY_Materials_Plumbing_MJ&hash=item3cd011d6f6
£2 each , got about 20
Re: Spare building stuff
« Reply #1 on: June 22, 2014, 05:52 PM »
Gaz , could do with two of those shower heads please ...... if nobody wants the 3rd i'll take all 3 at MK for £20   :daumenhoch:
Have you got any Mira shower hoses in your stash  ???
Cheers mate
« Reply #2 on: June 22, 2014, 06:48 PM »
Of course I have  :coolsmiley:
I'll bring you some hoses as well
« Reply #3 on: June 22, 2014, 07:02 PM »
The RAD diamond strikes again  :4_17_5:
This is better than Screwfix !!!   :D
Cheers Gaz  :)
Offline Howser
« Reply #4 on: June 22, 2014, 07:11 PM »
Hi Joff - I could do with one of those and would be happy to take the 3rd one off your hands for a 1/3 contribution if that's ok with you?
Many thanks  :daumenhoch:
« Reply #5 on: June 22, 2014, 07:20 PM »
That's cool with me Doug as long as it's good with Gaz  , i only need two hence what i put  ;)
Im collecting at MK  :daumenhoch:
« Reply #6 on: June 22, 2014, 07:25 PM »
Yes Doug can have one too  ;)
Do you need a hose with it Doug
Gaz..
Offline Howser
« Reply #7 on: June 22, 2014, 08:13 PM »
Thanks guys.  I'll be at MK too and happy to sort out cash then or before if needed.
I do need a hose and that would be appreciated if you have one please Gaz.
Offline MADD DOGG
« Reply #8 on: June 23, 2014, 10:59 PM »
need
a new bath
dark green composite front door,,,or blue,,or red
ha ha
