975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 05:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Swapping B1B sleeves - my new least favourite BMX job.......
Author Topic: Swapping B1B sleeves - my new least favourite BMX job.......  (Read 580 times)
Offline Bfellows
Whilst the finished results were worth it, getting them sorted has been an absolute twat.  I went the warm soapy water method and its taken me 2 days and I have a blister.  Thinners next time......
  • Andy
Re: Swapping B1B sleeves - my new least favourite BMX job.......
« Reply #1 on: June 06, 2014, 10:26 PM »
They look super cool though Bert. Worth the blisters I'd say. I've been there with F-1's, so feel your pain!
Offline chubby
  • Needs Pegs
« Reply #2 on: June 06, 2014, 10:33 PM »
Furniture polish bert  :daumenhoch:
Offline Bfellows
« Reply #3 on: June 06, 2014, 10:38 PM »
They nearly went down the garden at one point...... I ended up shoving tie wraps between the sleeve and grip and sliding the sleeve over them.
« Reply #4 on: June 06, 2014, 10:39 PM »
Nice grips  :coolsmiley:
I have changed the sleeves on a few of these and F1's , easiest way i have found is to have two flat pieces of plastic/metal with rounded edges  (bit like an old butter knife) and then use plenty of fairy liquid .... place the two pieces of metal either side of the grip area and unroll the sleeve over the top . You can then move the sleeve into the desired position without it snagging on the grip bumps , it has always worked for me and only takes about 5/10 mins .
Not sure i would ever use thinners tbh as it might react with the rubber  :-\
Offline steve69
  • aka. Steve Changa
« Reply #5 on: June 06, 2014, 10:56 PM »
I found it so much easier doing it with the grips fitted to the bars/bike  :coolsmiley:
I'm guessing most people attempt it with the grip in their hand so they can screw the middle section up a bit  :-\
« Reply #6 on: June 07, 2014, 08:34 AM »
Or you could just cut them off, would save a lot of pissing about
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #7 on: June 07, 2014, 07:52 PM »
Using thinners allows you to change them in 2 minutes!
