975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 07:21 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  acsz hubs rebuild?
Author Topic: acsz hubs rebuild?  (Read 498 times)
dannyboy
acsz hubs rebuild?
« on: August 18, 2006, 08:46 PM »
the rear hub is a bit grindy can the bearings be replaced ?
cheers
Re: acsz hubs rebuild?
« Reply #1 on: August 18, 2006, 08:51 PM »
yes mate loose balls keep them and replace from an old hub or take on to a shop they need to be same size.also check the seat where the bearings sit pop the dust cover of and clean and the screw on outer retainer see if its damaged.re pack with grease of you go.
dannyboy
« Reply #2 on: August 18, 2006, 08:55 PM »
yay cos the  araya rims are fairly spot on this could be a great rider if i cant find out the exact make of frame  :4_17_5:
« Reply #3 on: August 18, 2006, 08:56 PM »
put a piccy up mate..dan,
dannyboy
« Reply #4 on: August 18, 2006, 08:59 PM »
theres one on the gt? tread below this one
