975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  OS Axle Nut Size
Author Topic: OS Axle Nut Size  (Read 1698 times)
Offline Macmania
OS Axle Nut Size
« on: May 25, 2014, 09:52 AM »
Can anyone please tell me the size of axle nuts I need for a pair of Suzue Hubs (3/8 x 24T or 26T) ?
Thanks
Nathan  :)
Wanted: Anything MT Racing
Offline snoopy72
Re: OS Axle Nut Size
« Reply #1 on: May 25, 2014, 10:17 AM »
Hi Nathan,
3/8  26T's
I have a new set,
PM me your addy and i'll put them in the post on Tuesday   :daumenhoch:
« Last Edit: May 25, 2014, 10:32 AM by snoopy72 »
Offline chubby
  • Needs Pegs
« Reply #2 on: May 25, 2014, 10:22 AM »
Which is 3/8 unc if my memory serves me right.  24tpi is unf thread   :daumenhoch:
Offline snoopy72
« Reply #3 on: May 25, 2014, 10:28 AM »
SKYWAY mixed them up , sometimes they used 24 for one axle and 26 for the other.
Offline Bfellows
« Reply #4 on: May 25, 2014, 10:30 AM »
Thanks
Nathan  :)
I have hubs that take 24tpi front and 26tpi rear........... bloody typical.  Just count the threads!  My point being don't assume that they are one or the other.  For what it costs just buy a set of each and try them.
Offline snoopy72
« Reply #5 on: May 25, 2014, 10:35 AM »
Thanks
Nathan  :)
skyways ? I had a bit of a fall out with skyway, wouldn't have anything skyway even if it were FREE, bought a new set of tuff 2's and when I fitted the freewheel the chain alignment was miles out , not like a spoke wheel, you can't pull the rim over.
couldn't adjust the chainring because it was a fixed solid type on a motomag with a one piece crank and that was bog standard, can't pull the crank and chainring into the bb closer :nickswan:
The guy in Tech wouldn't have it , said his wheels are perfect and quality control is strict and there's me trying to do the chain alignment with a vernier and it was 8mm out.
The thread was fine but it was as if the hub had been moulded the wrong offset to the wheel (freewheel needed to screw on another 7mm) (sold them in the end and took a £20 loss ) funny that  ::) bought a set of z-rims and they fitted straight in without any adjustment.
Interested to know if anyone else has had alignment issue's with the new sealed bearing tuff 2's  ?
 :rant:
« Last Edit: May 26, 2014, 07:24 AM by snoopy72 »
Offline Macmania
« Reply #6 on: May 25, 2014, 12:54 PM »
Right, so I need 24T or 26T  :LolLolLolLol:
Offline chubby
  • Needs Pegs
« Reply #7 on: May 25, 2014, 05:06 PM »
I'd get some of both, make life easier  :daumenhoch:
Offline snoopy72
« Reply #8 on: May 26, 2014, 07:27 AM »
I'll send them on Tuesday :daumenhoch:
« Reply #9 on: May 26, 2014, 07:05 PM »
« Reply #10 on: May 26, 2014, 07:11 PM »
Offline Macmania
« Reply #11 on: May 29, 2014, 08:20 PM »
Thanks for the info chaps  :daumenhoch:
Big thanks to Snoopy who has sent me a couple of pairs FOC  :4_17_5:
  • Andy
« Reply #12 on: May 29, 2014, 11:25 PM »
Looks like you're all sorted Nath, but Suzue are defo 26tpi. I know as i have 2 sets of skyway axle extenders on my adidas, both stamped 26. I believe it's pot luck when dealing with Skyway tuff axles
