976130 Posts in 138974 Topics by 6408 Members - Latest Member: Bmxburryportwales December 20, 2025, 06:00 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skway riveting
Author Topic: skway riveting  (Read 12808 times)
Re: skway riveting
« Reply #25 on: April 05, 2014, 10:50 AM »
marty, where have they said that? ive never seen any advice from skyway.....im not saying they havnt, but id like to read what else theyve said.
Re: skway riveting
« Reply #26 on: April 05, 2014, 11:05 AM »
It says it on the replacement hub instructions.  Can't find my copy at the moment but it does state it.
Offline dirtskirt
Re: skway riveting
« Reply #27 on: April 05, 2014, 05:10 PM »
Im interested to know how this could be done
Look at mine -
The wheel itself is fine, just the hub flanges need changing.
Thinking caps on ???
Offline 84freestyler
Re: skway riveting
« Reply #28 on: April 05, 2014, 06:38 PM »
Exact same problem Dirtskirt!
Mine are that badly corroded you can't even make out the skyway stamp!   :(
Offline waza007
Re: skway riveting
« Reply #29 on: April 07, 2014, 12:50 AM »
rivets are not tapered!!
the reason skyway says which direction to punch them out is that the rivet shaft does get slightly distorted on the end that is riveted
If you were to punch that end all the way through the plastic hole it would haveten stretch or crack the plastic tuff
Re: skway riveting
« Reply #30 on: April 07, 2014, 12:11 PM »
Look at mine -
Have you bleached them yourself dirtskirt?  they look super white.
Re: skway riveting
« Reply #31 on: April 07, 2014, 02:10 PM »
So they are wider at one end than the other; what's a word that describes that  ::)
Offline jimwise68
Re: skway riveting
« Reply #32 on: April 07, 2014, 03:04 PM »
Marty, was going to put a pic of a TAPIR in but couldnt be arsed! lol
Offline dirtskirt
Re: skway riveting
« Reply #33 on: April 07, 2014, 09:56 PM »
[/quote]
Yeah , i gave it a soaking in diluted bleach, the flanges were already a bit pitted due to age and oxidization, but it didn't help when i used grease to try and protect them from the bleach because it seeped through and made them worse. so ive tried to give them a polish up but they are so difficult & awkward. i gave it a second bleaching this time with thick layer of Vaseline which done the trick, Also the freewheel was toatally seized on so i had get the angle grinder to cut it off, being super careful not to touch the ally.
A lot of work for a battered old flange  ;D
Can you still get replacement flanges anywhere?
« Last Edit: April 07, 2014, 10:01 PM by dirtskirt »
Re: skway riveting
« Reply #34 on: April 07, 2014, 11:05 PM »
Yeah I,m after a set of rear hubs/flanges.. Got a front set coming but think there's a few scuffs on them from replacement bolts.. Got in touch with wazu007 and he,s kindly agreed to send me some rivets! "Thanks Wazu"
I wonder if there's any way to forge the flange too? Wouldn't that be Great??
What bleech did you use dirtskirt? I read the thinner the bleech the better? And for how long, and any pre bleech cleaning or scuffing before hand?
Thanks
Re: skway riveting
« Reply #35 on: April 08, 2014, 08:17 AM »
I reckon i could fabricate a pretty good copy from mild steel, but i couldnt do the thread.
Offline dirtskirt
Re: skway riveting
« Reply #36 on: April 08, 2014, 09:24 PM »
Thanks
[/quote]
I just used lidl's bleach, 2 big bottles of the thick one I think? I had to add some water to get the whole wheel submerged. Gave it a slight scrub prior with warm water & washing powder & rough cloth.
Left it the bleach for a couple days I think.
Definitely need a heavy coat of Vaseline on the flanges tho to protect them, a good 10mm layer all over should do the job.
Re: skway riveting
« Reply #37 on: April 08, 2014, 11:32 PM »
thanks Dirtskirt.. If I can sort out the hub riveting I,ll bleech them without the hubs on the wheels..i Just need a good rear hub now? Got a post in the wanted section, anyone??
Re: skway riveting
« Reply #38 on: April 09, 2014, 12:03 AM »
There is a much easier way of getting a convincing looking finish to the original skyway rivets without the huge outlay or machinery.
Just get hold of some blind rivets
Then holding the correct size bolt in a drill, grind the desired shape for the head (this took seconds and with a bit of work with some wet or dry looked ace)
Tighten the two together with decent pliers with a small bit of leather/rubber protecting the heads against the teeth and with a drop of thread lock its job done  :daumenhoch:
Offline bobbbbsy
Re: skway riveting
« Reply #39 on: April 09, 2014, 12:21 AM »
waza group deal ??
Re: skway riveting
« Reply #40 on: April 09, 2014, 12:36 AM »
Yeah, I,ve read most of what can be done with bolts, blind rivet etc.. And it does luk good for show bikes. But i want to ride mine tho.
Re: skway riveting
« Reply #41 on: April 09, 2014, 08:40 AM »
If you want to ride it just use the replacement nut and bolt from the kits
Re: skway riveting
« Reply #42 on: April 09, 2014, 09:24 AM »
No reason why you can't ride them, a blind nut is just as effective as the skyway replacement nut and bolt set when it comes to strength.
Re: skway riveting
« Reply #43 on: April 09, 2014, 09:55 AM »
It may come to that mate if I can't rivet them.. I just think the nut and bolt look a little naff. Just my opinion tho :)
Re: skway riveting
« Reply #44 on: April 09, 2014, 10:07 AM »
if you used that method on the bolt (grinding) then used a dome nut - possibly ground down as well, it would look better than a standard nut and bolt.
Re: skway riveting
« Reply #45 on: April 09, 2014, 10:41 PM »
I,ve considered that too mate, that is a good second option to the rivets :daumenhoch:
Re: skway riveting
« Reply #46 on: April 12, 2014, 11:47 PM »
Rivets arrived and in just 5 days from Oz!
Big "Thank You" to wazu007 (he knows why) :daumenhoch:
"So it Begins"
Wish me luck fellow Radsters!
Offline bobbbbsy
Re: skway riveting
« Reply #47 on: April 13, 2014, 12:57 AM »
I HOPE IT BLOODY WORKS... :LolLolLolLol:
Offline waza007
Re: skway riveting
« Reply #48 on: January 17, 2016, 06:02 AM »
They are NOT wider at one end. FACT
when they get riveted the rivet shaft gets distorted (twisted)
If you try and push the distorted(bent) end through the plastic it MAY crank the plastic.
Offline Ady
Re: skway riveting
« Reply #49 on: February 16, 2019, 11:13 PM »
Old thread as needed some advice , so worthy of a bump.. :bump:
