975643
Dannygee
July 03, 2024, 06:03 AM
Tuf neck power disk - Redline double pinch flight crank
Topic: Tuf neck power disk - Redline double pinch flight crank (Read 657 times)
Sicura
Riding with Stabilisers
March 16, 2014, 08:44 PM »
Hi,
Does any one know if I will be able to easily fit a Tuff Neck power disk onto a Redline double pinch crank?
Thanks for your help!!
Munnyella
Look Back
Re: Tuf neck power disk - Redline double pinch flight crank
March 16, 2014, 09:03 PM »
Yes, you'll need a top hat washer though, think its a 19-23.8mm, sure someone else will confirm.
I did it on my old floval.
MM
Sicura
March 16, 2014, 09:08 PM »
Thanks!!
Sicura
March 16, 2014, 09:12 PM »
Is fitting the power disk an easy job? Or is there anything I should know about?
Munnyella
Look Back
March 16, 2014, 09:25 PM »
Nah, dead easy, if you do it wrong, it wont work, chain alignment is the trick, but you should have spacers in the bottom bracket kit to sort that.
MM
Sicura
March 16, 2014, 09:32 PM »
Unfortunately not, the crank came on a frame I brought! Any idea where I can the spacers from? At the moment it does not line up, it sticks out to far!!
Munnyella
Look Back
March 16, 2014, 09:35 PM »
get some pics up, so we can see where you are at.
MM
Sicura
March 16, 2014, 09:59 PM »
Hi,
This is how it is at the moment. I am waiting for the power disk to come through the post.
Thanks for your help on this!!
southern andy
Site Supporter
Tail Whip
March 17, 2014, 08:21 PM »
On the drive side, is there a spacer there in the shape of a cone
? If so then it could be removed for it to line up better with the freewheel.
Sicura
March 17, 2014, 08:32 PM »
Hi,
Yes I think there is! It revolves when you turn the pedals.
Thanks
