975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 11:52 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Serial number ID, is this a kuwi number?
Author Topic: Serial number ID, is this a kuwi number?  (Read 3320 times)
« on: February 26, 2014, 07:37 PM »
k7f19955
ive got a mystery frame.
nearest ive got is:
K, kuwahara, 87, february, but then its usually a 4 digit number, and this is 5.
who else made frames with a K starting letter?
Offline fischflo
Re: Serial number ID, is this a kuwi number?
« Reply #1 on: February 26, 2014, 07:50 PM »
if it were one digit less i'd say:
KZ-1 according to this
http://www.ozbmx.com.au/'showtopic=10588  ...that  aussieidiot (he's called himself like that) seems to know this Kuwie stuff
Kz-1
1987
June (= f)
frame no 19955  :crazy2:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #2 on: February 26, 2014, 08:54 PM »
Kz-1
1987
June (= f)
A 1987 KZ-1??? Kuwie stopped making them in 83!!! There is a 2007 reissue  ???
Does it have a gusset?
JMC had serial numbers beginning with K but no subsequent letters, just numbers, so rules that out too.
Offline fischflo
« Reply #3 on: February 26, 2014, 09:11 PM »
What about Raliegh Aero Pro
Just asking cuz i heard they have the same serials as Kuwi Laserlites, and i also heard that lazer lites sometimes have the same K starting serial as KZ-1s... :-X  I'm lost Phil, sorry ....but you know Rad someone will come ....sometime :D
 "help"
« Reply #4 on: February 26, 2014, 09:25 PM »
thanks fisch...
it has no gussets at all.
round brake bridge, standard double diamond. similar to a 87 fox, exept for the rear drops, which are identical to a schwinn predator.
Offline fischflo
« Reply #5 on: February 27, 2014, 01:26 PM »
 ... like 96 or 97
and not sure on the serial
but seem to start with K & it's got Predator like drop outs ......and perhaps yours is chrome, too....? :D
Kawasaki Z1 courtesy saylor
->http://bmxmuseum.com/bikes/kawasaki/3715
......made by Huffy
« Last Edit: February 27, 2014, 01:29 PM by fischflo »
Offline fischflo
« Reply #6 on: February 27, 2014, 04:06 PM »
FORGET IT ........................just saw the stupid cable mounts >:( ...was so close, even the serial number would've been pretty similar:   K+97+letter+5 digit no     ...hrumph
The Kuwahara Scamp ........has dropouts practically identical to a Schwinn Predator's ..flat brake bridge
The Kuwahara Pantera  ........has dropouts practically identical to a Schwinn Predator's ..but different serial
« Reply #7 on: February 27, 2014, 05:08 PM »
also, the kuwi pantera has oval downtube.
scamp has different brake bridge.
the predator has identical dropouts, no gusset, but the ends of the main tubes have a slight flare.
at the moment im thinking its a cycle pro greg hill signature/ streetlegal.
the one i have has identical forks, same rear drops, same brakebridge, same brace between the chain stays.
aparently they were made in japan, by a maker with a "k", cant remember the name now, but they made some burners too....
Offline fischflo
« Reply #8 on: February 27, 2014, 05:19 PM »
cool - only knew the one with the older drops
..same serial config?
« Reply #9 on: February 27, 2014, 05:26 PM »
thanks for your help fisch.
that one you posted is one of 3 made. they seem to have 3 different rear drops, 2 types of forks, and the gusset reinforcement on one.
the models are street legal, signiture, replica, and competitior. the replica is very nearly a ghp type frame.
mine has the landing gear type forks shown above, and the drops with the pierced triangle.
No doubt it was a relatively low end frame, heres a pdf
http://oldschoolmags.com/tests/Cyclepro_GH_sig_model_Plus8411.pdf
he was sponsered by cycle pro, and put his name to what seems to be 2 generic type frames, and one ghp lookalike.
Offline fischflo
« Reply #10 on: February 27, 2014, 05:31 PM »
yep those forks are a giveaway  ----- i wouldn't even bother with the stupid serial, job done.
Nice find. :daumenhoch:
