975755
TattooedYorkie
September 21, 2024, 03:31 PM
bolts for alloy tuffs.. rear size and where from??
Topic: bolts for alloy tuffs.. rear size and where from?? (Read 717 times)
spadey99
Flip-Whip
February 25, 2014, 10:26 AM »
Guys I need some bolts to replace a hub on a rear alloy tuff. . What size length etc do I need and anyone got any links??
Steve
Bikes are there to be ridden, so why do I have so many.....
Jaan
Tail Whip
A.K.A. Chris
Re: bolts for alloy tuffs.. rear size and where from??
February 25, 2014, 11:12 AM »
Here you go Steve. Just don't spend all your time drooling over the 1st Gens...
http://mauricemeyer.net/cgi/mm.pl?datafile=../general/BMX.txt&page=BMX/Colored_Graphite_Tuffs
Actually, come to think of it - is bolt length in that article?
Last Edit: February 25, 2014, 11:18 AM by Jaan
spadey99
Flip-Whip
February 25, 2014, 11:44 AM »
Cheers chris will have a read later
Howser
Curb Endo
February 25, 2014, 07:01 PM »
Didn't bendycat have a thread on this and does axle replacements kits? Worth dropping him a pm to see if he can help out.
spadey99
Flip-Whip
February 25, 2014, 08:35 PM »
cheers mate, I think Bendy did the spindles... got some off him....
Jaan
Tail Whip
A.K.A. Chris
February 25, 2014, 08:41 PM »
You can still pick up Skyway hub replacement kits Steve but thats probably a more expensive way of fixing them. Can't you measure the original rivets...?
Bfellows
Flip-Whip
February 25, 2014, 09:09 PM »
You're in luck - they are 4.2mm x 64.43 which makes me think they are most likely imperial........ 5/32 x 2 and 17/32...... Or just buy 4 x 65mm and be done with it. Ere to help......
spadey99
Flip-Whip
February 25, 2014, 09:28 PM »
Bert I love you bro
so what would I search on e bay?
? Im useless fellas....
Bfellows
Flip-Whip
February 25, 2014, 09:40 PM »
Search for M4 pan head bolts - if memory serves, you can't get 65mm, so get 70mm and trim down. You need pan heads so the chain clears them when fitted.
spadey99
Flip-Whip
February 25, 2014, 09:51 PM »
cant find em on e bay... only 60mm length......
Bfellows
Flip-Whip
February 25, 2014, 09:59 PM »
They're thin on the ground.........
http://yambits.co.uk/bzp-panhead-screw-4mm-70mm-p-26934.html
Or
http://pages.ebay.com/link/?nav=item.view&id=390618988853&globalID=EBAY-GB
Don't forget you need nyloc nuts to suit.
Last Edit: February 26, 2014, 07:46 AM by Bfellows
Bfellows
Flip-Whip
Reply #11 on:
February 25, 2014, 10:00 PM »
Or these
http://www.accuscrews.co.uk/pozi-pan-head-screws/9311-SPP-M4-70-A2.html
