975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chainwheel options for flight cranks?
Author Topic: Chainwheel options for flight cranks?  (Read 796 times)
Offline Bfellows
« on: February 21, 2014, 07:56 PM »
If I choose not to use my redline chainwheel what else - power disc etc would fit.  I'm specifically thinking that the lug (?) on the flights is bigger than on say a one piece crank.  Cheers, Bert
Offline That Swan Guy
Re: Chainwheel options for flight cranks?
« Reply #1 on: February 21, 2014, 08:06 PM »
depends how old the flights are. The new twin pinch will take a power disc :daumenhoch:
Offline Bfellows
« Reply #2 on: February 21, 2014, 08:12 PM »
Old, 401 single pinch, full wrap..........
« Reply #3 on: February 21, 2014, 08:14 PM »
have a look through the museum. loads of the high end bikes have single pinch flites on, so you get to see what looks good with them as well as what fits the drive bolt.
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #4 on: February 21, 2014, 11:09 PM »
Bert, I have Tuff Neck and PPP fitted to full wrap flights.  You also just happened to have been sent a picture of 3 Tuff Neck power discs
Coincidence I assure thee  ;D
Offline Bfellows
« Reply #5 on: February 21, 2014, 11:18 PM »
Coincidently I've just sent you an email......... ;)
Offline ORB
« Reply #6 on: February 21, 2014, 11:25 PM »
Top Hat Washer ;)
12
Offline kalex
« Reply #7 on: February 22, 2014, 09:32 AM »
Yes I've had a tuf neck power disc that I had fitted to full wrap single pinch 401's but as ORB said you'll need a top hat washer as the bb spindle has a smaller diameter
« Reply #8 on: February 22, 2014, 12:57 PM »
Top Hat Washer ;)
^^^ Bang on, even Redline's own instructions which can be found in the tech sticky section shows a Sugino type spider being used.
Offline ORB
« Reply #9 on: February 23, 2014, 09:13 PM »
Ive forgotten more than i forgot that i knew. but i forgot that.
12
Offline Bfellows
« Reply #10 on: February 23, 2014, 09:20 PM »
Embarrassingly I have a copy of the fitting instructions, but have never read that far down.......
Offline kalex
« Reply #11 on: February 23, 2014, 11:53 PM »
i've posted in your wtb thread
