975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 09:50 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  brake lug help
Author Topic: brake lug help  (Read 1417 times)
Offline gib66
brake lug help
« on: February 19, 2014, 08:30 PM »
help i need a new 990 mount
i have just got new frame and one of the removable mounts is missing out the box are they all the same ie can i just buy one from somewhere or even better anyone got one or matching pair
frame doesnt have warranty either asit is new but a year old from someone who bought it but never built it
Offline Dannywhac
  • return of the whac
Re: brake lug help
« Reply #1 on: February 19, 2014, 08:44 PM »
They're not all the same fella - Fit one's will fit S&M ones etc, but won;t fit other companies.
What frame is it?
Offline gib66
Re: brake lug help
« Reply #2 on: February 19, 2014, 09:00 PM »
booo supercross passion dirt frame
Offline gib66
Re: brake lug help
« Reply #3 on: February 19, 2014, 09:07 PM »
the screw in part to go in the frame is as near as 12mm if this helps
rodriguez
Re: brake lug help
« Reply #4 on: February 20, 2014, 01:00 AM »
option a email supercross and they might send you some
http://supercrossbmx.com/
option b buy some after market ones and try them
http://www.alansbmx.com/8082/products/hoffman_bikes_removable_brake_mount_kit.aspx?origin=pla?kwd=&gclid=CKz_6eS_2bwCFSbnwgodpBwAfA
check this out, probably c or d you are after.
http://www.stolenbmx.com/brake-mounts
option c take frame to a bmx shop and try some
« Last Edit: February 20, 2014, 01:05 AM by rodriguez »
Offline Dannywhac
Re: brake lug help
« Reply #5 on: February 20, 2014, 09:13 AM »
Don't buy any of them listed lugs above - some lugs also come with pass through bolts and not threaded bases like the ones in the links above, and by the looks yours has curved mounts which non of the above will fit.
Deffo find out which type you need first - email Supercross and ask em.
rodriguez
Re: brake lug help
« Reply #6 on: February 20, 2014, 07:39 PM »
That's what I'd do   :daumenhoch:
Offline oldtired
  • Dirty Old Man
Re: brake lug help
« Reply #7 on: February 20, 2014, 09:00 PM »
was it the black one on ebay Greg?  if so , been looking at it deciding weather or not to hit the bin button ,
 Ask Ed to send a pic of his , i think its the same mounting on his SC Extention ,  i think  its an odd mounting, the boss screws into the frame rather than the bolt holding it in place ,
Offline Dannywhac
Re: brake lug help
« Reply #8 on: February 20, 2014, 09:18 PM »
It looks to all intent that they're similar to the S&M/Fit lugs - curved plate with a bolt through:
Your Frame:
S&M/Fit Lugs:
But deffo find out from Supercross which one's they are - it'll save ya a twenty quid mistake  :daumenhoch:
Offline oldtired
  • Dirty Old Man
Re: brake lug help
« Reply #9 on: February 20, 2014, 09:32 PM »
i think the SC  catalog shows the curved bit separate and the boss is threaded into the frame so a normal/stock  mounting bolt can be used , could be a pre production design though.
Offline gib66
Re: brake lug help
« Reply #10 on: February 20, 2014, 09:58 PM »
Boss is threaded with curved washer
Offline oldtired
  • Dirty Old Man
Re: brake lug help
« Reply #11 on: February 20, 2014, 10:10 PM »
looks like Supercross will be the best bet then Greg  :daumenhoch:
the boss will probs be standard one,  i think they are either 8mm or 10mm thread  but the washer will be the tricky bit ,
Offline gib66
Re: brake lug help
« Reply #12 on: February 20, 2014, 10:26 PM »
I have the washer
