975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 11:44 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Powder Coating
Author Topic: Powder Coating  (Read 1055 times)
Powder Coating
« on: August 13, 2006, 09:16 PM »
Ok Im getting a frame & Forks Powder Coated soon, is it best to mask up inside the Headtube, Bottom Bracket & around the forks where the headset fits.
Re: Powder Coating
« Reply #1 on: August 13, 2006, 09:18 PM »
mask off the thread on the fork steerer, and any ad lugs (where the brake mounts) but leave the rest
Re: Powder Coating
« Reply #2 on: August 13, 2006, 09:32 PM »
Will I get the headset & Bottom Bracket in ok ?
Offline Steve P
Re: Powder Coating
« Reply #3 on: August 13, 2006, 10:16 PM »
I normally skim the excess powder out with a Dremmel Chris. Leaving the open end tubing unmasked ensures the ends are nicely coated
Steve
Re: Powder Coating
« Reply #4 on: August 13, 2006, 10:24 PM »
OK thanks guys, this is the first time Iv taken anything to be powdercoated in a few years.
Re: Powder Coating
« Reply #5 on: August 13, 2006, 10:27 PM »
Steve
exactly right
nibble the paint off when you fit the cups
the powder coaters where i go sometimes mask it for me and do a poor job. i have told them to cease this folly.
mask the fork threads though. nitromors will fetch it off if you dont mask, but its a bit laborious
MeddlE
Re: Powder Coating
« Reply #6 on: August 14, 2006, 12:49 AM »
If it's a euro bottom bracket then mask off that thread too.
weston
Re: Powder Coating
« Reply #7 on: August 14, 2006, 10:15 AM »
your powder coater should mask all this off for you as there is only certain tape you can use for this job, just tell them when you take it..
Re: Powder Coating
« Reply #8 on: August 14, 2006, 10:18 AM »
i have used sticky labels (i have them in abundance) to mask the steerer threads before
and other times just regular tape
Re: Powder Coating
« Reply #9 on: August 14, 2006, 06:52 PM »
So should I tape it up with masking tape or leave it to the powder coater  ???
Offline superbikedan
Re: Powder Coating
« Reply #10 on: August 14, 2006, 07:08 PM »
dont mask it yourself, the tape you use should be high temp,  i tend to use bearing cups that mask it perfectly and all i do is tap them in half way, your powder coater should know this or supply him with an old set of cups, one last try is use your own cups then strip them after.
Re: Powder Coating
« Reply #11 on: August 14, 2006, 07:22 PM »
Tell you what Dan, I think I will wait until I can get over to Rom & let you do it  :daumenhoch:
