975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stripped stem threads
Author Topic: Stripped stem threads  (Read 511 times)
Offline laidback
« on: February 02, 2014, 08:11 PM »
Evening all!
Well the team master build is well underway. However i was bolting up the bars today and noticed that two of the threads in the bolt holes are stripped "help" They are completely smooth on the inside.
It's an aluminium Haro Team stem.  What are my options?? I'd like to avoid using bigger bolts, as i'd have to mess around with the stem cap holes.  Get someone to alloy weld them and re drill/tap?  Or redrill and Heli- coil?
I'm pretty handy, but i think this job might have to be farmed out to someone else.
Any suggestions from you guys is greatly appreciated. Second build, second fooked stem :2gunsfiring_v1:
Offline john4130
Re: Stripped stem threads
« Reply #1 on: February 02, 2014, 09:09 PM »
i would say heli coil, you wont see them once the stem caps on anyway.
Offline HUTCHMAN
« Reply #2 on: February 02, 2014, 09:12 PM »
+1
« Reply #3 on: February 02, 2014, 09:12 PM »
Heli coil  :daumenhoch:
Offline Chapperz
  • Always too slow on the dib dobs!
« Reply #4 on: February 02, 2014, 09:36 PM »
Any decent engineering shop locally should be able to do it cheaply. If you can drill and tap though the kits are cheap enough.
http://www.ebay.co.uk/itm/25-Piece-Helicoil-Thread-Repair-Kit-M8-x-1-25-x-10-8mm-/271245164223
The choice is yours.
Cleethorpes Old School Ride Out 2018. 14th July 2018
Offline laidback
« Reply #5 on: February 02, 2014, 10:13 PM »
Thanks chaps, might give it a go myself.. what's the worst that can happen? ;D
Offline laidback
« Reply #6 on: February 02, 2014, 10:20 PM »
Does anyone know the size i need for standard haro stem bolts?
« Reply #7 on: February 03, 2014, 11:22 AM »
Heli-coil definitely, not the hardest job in the world, you just have to be able to drill straight (use a pillar drill).
