975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 05:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  help gt ?? got it today more piccis is this it??
Author Topic: help gt ?? got it today more piccis is this it??  (Read 2021 times)
dannyboy
Re: help gt ?? got it today more piccis
« Reply #25 on: August 18, 2006, 09:37 PM »
wot do yuz reckon this is it ??[img][/img]
duncan
Re: help gt ?? got it today more piccis is this it??
« Reply #26 on: August 20, 2006, 01:04 AM »
Did you check out the links I PM'ed a while back - you'll see the frame is very likely to be MCS made.
There's always the possibility a far-eastern company copied the MCS design, but doubtful, no-one has said so far.
Your bike does look similar to many other makes, but unless you spot another bike with the same BB gusset and brake bridge design you should assume MCS rather than Scorpion, CW etc.
Forks are Akisu as you say, maybe added later when originals were lost?
The bike you posted above, it's impossible to tell unless you get closeups of the BB/brake bridge, the headtube gusset is different too.
There are bikeframes in the links I PM'ed that are exactly your frame, only differing because they have no headtube gusset. I'm guessing you just have a slightly different model.
Hopefully someone on this site or another will come up with a positive identification,
Best of luck.
« Last Edit: August 20, 2006, 01:22 AM by duncan »
dannyboy
« Reply #27 on: August 20, 2006, 12:47 PM »
cheers bud  :4_17_5:
