975855 Posts in 138949 Topics by 6382 Members - Latest Member: bmxbaz January 25, 2025, 04:54 AM
RADBMX.CO.UK  |  Old School BMX 1980 - 1988  |  Old School Race (riders ready, pedals ready... GO!!)  |  Supergoose u.k Supergoose usa
Author Topic: Supergoose u.k Supergoose usa  (Read 86972 times)
Re: Supergoose u.k Supergoose usa
« Reply #25 on: August 14, 2006, 11:48 AM »
the plot thickens.
weigh it greame.
i will measure the tubes on my super and expert
tbh i think the front ends are the same. if the super has thicker tubes, then they aint much thicker. i want 2" or no dice
« Reply #26 on: August 14, 2006, 11:50 AM »
this is another good way to spot a supergoose
may be the same on high end mongs though, but its different to the caliexpert
« Reply #27 on: August 14, 2006, 11:55 AM »
is that a crack?
Offline jimmyp
« Reply #28 on: August 14, 2006, 11:57 AM »
A good way to spot a usa supergoose but as we can see not a good way to spot a uk version. The number for my usa super is k3002471. The number for the u.k. super is M4J19528. Im not sure we've been ripped of because th uk bike is lighter all round and lighter is good :) :) :)
Offline kdw712
« Reply #29 on: August 14, 2006, 11:58 AM »
My understanding is this
mongoose made the supergoose as 100% chromo F&F
later in the states they made a chunky version of it
a few of which are over here now
i can only assume they did this after the pro class came out
tube sizes being the same as the pro class just not as thin walled
uk spec bkes stayed the same diamter top and down tube
according to adverts etc
the expert was a USA only bike and had so it seems both all tubes and main frame only
over the years, as i too had a all tubes frame but it had all steel companents
but have heard / seen main tube only frames
the cali has been seen in both varients, though in the UK up to 85 ish
it was a main tubes only frame.
experts and calis generally have a single hole in the rear brake bridge
where as a super should have the 3 hole bridge
the grand prix - well lets forget that for now
looking at the pics posted one has 3 holes and the other has a single
to my mind one is a super (3 hole) the other is a cali / blue max poss
or if all tubes an expert
note all this is subject to change as mongoose it seems just churned them
what are the serials on them both ?
is one the the 84 you mentioned in the pm ?
as we could have another twist in the mongoose frame story here ....
cheers Kev
Offline jimmyp
« Reply #30 on: August 14, 2006, 12:02 PM »
Yes it is the one mentioned in the pm. But looking at the brake bridge on the uk bike i don't think you could put three holes in there it would be too weak. the only reason they have done it on the usa version is because it bigger because the rear is wider on the usa frame :D :D
« Reply #31 on: August 14, 2006, 12:04 PM »
ok you got me
i will strip the expert and weigh it.
if it weighs the same as yours i am gonna put supergoose stickers on it and sell it.
it's gonna be lighter than a supergoose, as it has thinner tubes on the back. not much lighter though.
my super is an 83, and my expert is an 84
Offline kdw712
« Reply #32 on: August 14, 2006, 12:04 PM »
you could be right
i know a lot of UK / european bikes were built in france by motobecane (sp?)
so more varients due to different factories etc
ruler
my cali is stamped there too .....
as were pro classes
mongoose - great bikes just hard to work whats what
cheers Kev
Offline jimmyp
« Reply #33 on: August 14, 2006, 12:05 PM »
ok you got me
Lighter than which supergoose? uk or usa? remember the uk is lighter
« Reply #34 on: August 14, 2006, 12:06 PM »
ok you got me
if it does weigh the same, according to this thread, and there are a lot of knowledgable people on it, there is no way to tell the difference.......so you would be ok....
« Reply #35 on: August 14, 2006, 12:07 PM »
you got a pic of the expert greame?
« Reply #36 on: August 14, 2006, 12:07 PM »
what year did the super 3 come out?
Offline jimmyp
« Reply #37 on: August 14, 2006, 12:08 PM »
83 me thinks
Offline kdw712
« Reply #38 on: August 14, 2006, 12:08 PM »
i would say the same
1983
early pro class were seen around 1982
(stidds has one)
the first 3 came over with maloney ruffell + ??? at end of 1982
so new generation of non gusset gooses woiuld of followed from there
cheers Kev
« Reply #39 on: August 14, 2006, 12:10 PM »
then my super is an 83, first one
it has the rear fatter tubing and different bb height (and the 3 hole bridge)
did the down tube increase in size in later years?
« Reply #40 on: August 14, 2006, 12:15 PM »
this is the only pic i have uploaded. took it last weekend. it was slung together with spare parts to put into storage (at my mate's house) while we move house.
i have to drop off 9 framesets there tonight, so i will get the "x" back to strip, and measure the girth of the super tubes
Offline kdw712
« Reply #41 on: August 14, 2006, 12:15 PM »
not sure
 i would have thought fat rear end tubes would have had thicker downtube like the pro class
cali rear is about same size as the box section it joins onto
pro class etc is bigger than it
you may have another option / twist
and i thought i had this "whats my goose ?" sussed  :(
cheers Kev
« Reply #42 on: August 14, 2006, 12:18 PM »
as far as i knew, all the supers had larger tubes at the back. thats what made them SUPER !!!!!!!!!!!!
« Reply #43 on: August 14, 2006, 12:20 PM »
thats what i thought.....are the tubes a different diammeter on that expert?
Offline kdw712
« Reply #44 on: August 14, 2006, 12:22 PM »
ah now if you look at the uk advert you can see it has same diameter tubes as the box section
i have a US test where they state they have beef it up to the pro class spec
thus proving i had a Us supergoose and not a pro class
thats not to say the uk models didn't have the tubes
just theres never any mention of it that i have seen
cheers Kev
« Reply #45 on: August 14, 2006, 12:25 PM »
i had a super, cali and expert frame all together to compare them one time
the expert and cali were identical, and the only difference on the super was the rear end
the front end looked the same though. exactly the same
maybe in later years the super had a beefier downtube, but the back end was always chunky.
i see no evidence to say that there was a UK supergoose that had the cali rear end.
i am up for being proved wrong though. mongoose did have some strange deviations. but that was mainly in the gusseted models
Offline Bananaman
  • Le Mans Man
« Reply #46 on: August 14, 2006, 12:28 PM »
Am lookin for a decent Proclass and am now shattin it in case I end up with a supergoose frame decalled up as a Proclass :-\
Offline jimmyp
« Reply #47 on: August 14, 2006, 12:29 PM »
The only reason iv'e started this debait is because there have been a number of uk supergoose's on ebay and at the time i thought the same as you dudes that supergoose's had three holes in the brake bridge. But when i asked  that question to the people who were selling they all said no the bikes just had the one hole. This got me thinking back to my supergoose i had as a kid and can't remember it having three holes either. Now ive stumbeled across this frame as well and it also does not have three holes. One of the sellers even posted a pic of the brake bridge as you can see in the photo's
Now you can't tell me that all these bikes have been stickerd wrong by some unscruplias bike dealer. The supergoose only cost about £70 more than a cali. By the time you put all the correct components on it would have cost him more to do. And i was getting worried because maybe people are buying these bikes of ebay looking at them and thinking this is not a supergoose. Then ripping all the stickers of and putting cali stickers on, when infact they are supergoose's after all, UK Supergoose's infact.
« Last Edit: August 14, 2006, 12:31 PM by jimmyp »
« Reply #48 on: August 14, 2006, 12:38 PM »
i have never heard of a uk supergoose until reading this thread.
bitd the supergoose stickers would be easy to get, and would make a great hop up for your cali though
if i was looking on the bay, and there was a supergoose which didnt have the supergoose hallmarks, then i would probably still buy it, but not for supergoose money.
ebay sellers aint always legit either. the amount of burners stickered up as TA's. a uk TA?
« Reply #49 on: August 14, 2006, 12:38 PM »
good point, it is unlikely.
but, if i was to buy a supergoose, i would want the fat rear end, 3 holes, despite the fact that there may or may not have been a uk version.
good debate though. you learn somthing new everyday.
