975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 23, 2024, 07:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Mongoose seatpost removal help..
Author Topic: Mongoose seatpost removal help..  (Read 945 times)
Offline spadey99
« on: January 05, 2014, 09:00 AM »
Hi guys
Got this as a donor as cheap and nice forks and stamped b b and headset but when its landed its better than thought as you can see..
So someones had a go at removing it and have sawed through the post inside.. but whats best way to remove more??
Anyone know anyone who would do it... is drilling easy?? My mate has a decent workshop and bench drill etc...
Cheers steve
sent from my lavatory
Bikes are there to be ridden, so why do I have so many.....
Offline southern andy
Re: Mongoose seatpost removal help..
« Reply #1 on: January 05, 2014, 10:20 AM »
If the seatpost is an Ali one then Caustic soda it. Takes a while though (days not hours). You'll have to keep topping the soda up.
Otherwise it can be drilled. Slowly does it though and make sure you go through the drills in size e.g start small and work your way up. Be careful to follow the angle of the seat tube though as you don't want to drill through the frame itself. When the post becomes thin start pressing a screwdriver in to try and break what's left of the post rather than drilling it. Better to be safe than sorry.
Offline spadey99
« Reply #2 on: January 05, 2014, 10:44 AM »
Cheers bud... I think it's alloy bud just checking.... so fill seat post tube up with caustic soda??? It wont damage the chrome or anything if spilt?
Or just go steady and let it fizz round the seatpost to eat the alloy
Steve  :daumenhoch:
« Reply #3 on: January 05, 2014, 10:48 AM »
Correct, it wont damage the chrome.
Be aware though the fumes off it are immense. Burns like buggery if it gets on your skin aswell.
Offline spadey99
« Reply #4 on: January 05, 2014, 10:52 AM »
Cheers mate... will look at it... make it super strong then. ..
Offline spadey99
« Reply #5 on: January 09, 2014, 08:26 PM »
right guys im getting there with this seat post but what is best caustic soda??? I got cheap stuff..... Also I put it in but after an hour it goes off so I have to change it........ :tickedoff:
Just any tips on caustic soda use or other chemicals.... :knuppel2:
